Finishing tips needed
Forum topic by Shopsmithtom posted 2094 days ago 697 views 0 times favorited 8 replies Add to Favorites Watch
View Shopsmithtom's profile
Shopsmithtom
769 posts in 2391 days
2094 days ago
I’m kooking for a tip or two on finishing cedar. I’m using it as a liner in a box and wondering if I should finish it or just leave it. It’s not a humidor, or anything that needs to be like a cedar chest. I’m just using it as a liner because I have some scraps that will fit and look pretty good. (I’m big on using up the wood I have laying around)
These pieces were in a box of closet lining pieces that I got at a yard sale. I did notice that some pieces seem to be bleeding sap that has crystallized in a few spots.
Anyway, I’m looking for some advice (opinions) on on whether to apply some finish, and if so, what kind, keeping in mind that I’m a simplistic kind of guy, so I don’t want to get too exotic. (remember, I’m using yard sale wood and, did I mention that the box I’m lining also came from a yard sale..different one, though).
Oh, and don’t worry, I’ll be sure to show it off when I’m done. -SST
-- Accuracy is not in your power tool, it's in you
8 replies so far
View bryano's profile
bryano
546 posts in 2130 days
#1 posted 2094 days ago
Is this airomatic cedar? If so i wouldnt put any finish on it, mite take away that wonderful smell.
-- bryano
View frank's profile
frank
1492 posts in 2403 days
#2 posted 2094 days ago
Hello SST;
—-well depends on whether you want to retain the smell or go for a look of finish?
I use cedar for backsplashes when I’m doing wood (white oak) countertops, so I will then contrast with cedar. I will apply a coat of tung oil, then apply a coat or two of de-waxed shellac, which I will then follow with several coats of oil poly….
Bear in mind that you can also just go with the tung oil, although in order to speed the drying process up some, I usually cut 50:50 with gum turps (mineral spirits works great also) and then use some Japan dryer.
As to stopping the bleeding sap, try using two coats of shellac on the wood. You only need to go with the de-waxed if you are planning on applying a top finish over such as poly or a varnish.
I also think it’s great that you are using all your wood and as to any finish being simple….well, finishing is an art in it’s own, but any who want to, can master this art.
Thank you.
GODSPEED,
Frank
-- --frank, NH, http://rusticwoodart.tumblr.com/
View MattD's profile
MattD
149 posts in 2141 days
#3 posted 2093 days ago
It’s a personal preference really. My preference would be to sand it around 220 grit occassioanlly to clean it up and restore the smell of the cedar. You might also consider using a cedar/mineral oil that would provide a reasonable finish and maintain the smell. Looking forward to seeing the new project!
-- Matt - Syracuse, NY
View Ethan Sincox's profile
Ethan Sincox
765 posts in 2370 days
#4 posted 2093 days ago
If you want to just seal up the gum deposits so they don’t leak anymore, you just need to hit it with a coat or two of dewaxed shellac.
BTW, if you ever do get to making a humidor, you’ll want to use Spanish cedar, which is really more like mahogany, than the western or eastern cedar you’re used to seeing.
Good luck on the box!
-- Ethan, http://thekiltedwoodworker.com
Douglas Bordner
3907 posts in 2260 days
#5 posted 2093 days ago
Echoing what others have said, dewaxed shellac if you want to seal it, burnishing it to P400 grit if you want it to scent the project.
34396 posts in 2597 days
#6 posted 2093 days ago
I’m with leaving it alone and enjoy the smell.
Shopsmithtom
#7 posted 2092 days ago
Thanks for all the tips. I’ll be digesting it all and, hopefully, moving forward soon. -SST
View Woodminer's profile
Woodminer
69 posts in 2134 days
#8 posted 2090 days ago
Leaving it naked does not preserve the color. Wood oxidizes. Almost all wood changes color with that process.
If you’re interested in color, use a lacquer or other water clear product to avoid color changes. Lacquer will mask the scent (darn) but leaves the color pretty much alone. And if you’re wanting the scent, too, you could always make it a dry potpourri, right? Add some fresh cedar chips now and then, keep dust in a little pouch hidden in the bowl…
I’m working on a little cedar bowl right now and know that I have to finish it so that it won’t crack. Wild grain patterns, very cool, but am concerned about the cracking. LOVE the aroma of turning it and will probably put some chips in a pouch nearby once it’s displayed. Padauk’s aroma is also wonderful, but fleeting. Might do the same there…
-- Dean, Missouri
