exterior finish for exterior furniture in the southeast..North Carolina
Forum topic by Dan Hux posted 59 days ago 145 views 0 times favorited 3 replies Add to Favorites Watch
Rockler
View Dan Hux's profile
Dan Hux
161 posts in 274 days
59 days ago
Topic tags/keywords: question
What is a good primer and paint combination to use when finishing furniture for exterior use in the southeast (North Carolina).. garden benchs, tables, adirondack chairs..that sorta stuff?
-- Dan Hux,,,,Raleigh, North Carolina
View Dustmite97's profile
Dustmite97
182 posts in 120 days
49 days ago
Not sure if this would work in your situation, but what I do is use regular paint(indoor or outdoor) and then spray it with a couple coats of varithane spray. It gives a good shine and it is very durable.
-- Remember, measure twice, cut once
View gerrym526's profile
gerrym526
139 posts in 708 days
47 days ago
Any good quality primer and paint you’d use for your house (soffits, facia, window trim) will work. Outdoors, wood is especially vulnerable to UV rays (breaks down the lignin material, and rots the wood), so anything with a pigment in it will protect the furniture from the elements.
-- Gerry
View LesB's profile (online now)
LesB
557 posts in 343 days
47 days ago
I agree with Gerrym526 but I would add check with your local paint store. Paint manufacturers adjust their paint for each region of the country. In Calif. they adjust for sun, in Washington for rain, and so on. A good primer and a gloss exterior paint should do the job.
I would definitely stay away from coating with a clear coat product, it will only dull, crack, and peel in a couple of years of sun. Even marine spar varnish needs to be sanded and re-coated every two or three years.
-- Les B, Oregon
