Building very thick table top
Forum topic by WOODIE1 posted 06-30-2015 03:27 PM 2711 views 0 times favorited 15 replies Add to Favorites Watch
View WOODIE1's profile
WOODIE1
117 posts in 2306 days
06-30-2015 03:27 PM
Ok I was watching a TV show Million Dollar Contractor. I know it is a TV show but it is about renovating high end apartments in NYC and I find it interesting.
I saw they were building a round walnut table top. It was about 3-4” thick. How they made it was to join board for say a ordinary table top and then do another just like it. they then glued the together making a sandwich. The part that caught my attention was they glued the to tops perpendicular to each other so that the boards now run 90 degrees to each other. It looked amazing in the end as they used a cmc to then cut the circle and edge details.
My question is isn’t the expansion crossing each board like that going to separate the two halves?
15 replies so far
View SirIrb's profile
SirIrb
1239 posts in 1258 days
#1 posted 06-30-2015 03:36 PM
Think plywood. I wouldnt say so. Even though plywood is turned off a log it is the same principal with the grain running perpendicular to each other. You are about to make the thickest and heaviest piece of 3 ply plywood you ever saw.
EDIT: Hummm, how are you going to cut it round. Can you get a 4” router bit?
View johnstoneb's profile (online now)
johnstoneb
2942 posts in 2200 days
#2 posted 06-30-2015 03:38 PM
It’s also going into a climate controlled facility.
-- Bruce, Boise, ID
View Aj2's profile
Aj2
1440 posts in 1825 days
#3 posted 07-01-2015 04:05 AM
You betcha it’s going to delaminate if the two sections were 90 to each other.Since you’re calling them boards they be way to thick,to be anything close to plywood. Those diy shows are full of misleading wood working ideas.
-- Aj
View Lumberpunk's profile
Lumberpunk
334 posts in 2364 days
#4 posted 07-01-2015 04:17 AM
I have seen similar things tried, they split, maybe in a climate controlled facility it would be ok.
-- If someone tells you you have enough tools and don't need any more, stop talking to them, you don't need that kind of negativity in your life.
View emart's profile
emart
445 posts in 2655 days
#5 posted 07-01-2015 04:28 AM
Realistically the grain should run in the same direction when the wood is that thick maple is stable but it will still move slightly. As for the router bits you can get extra long bits from a CNC supplier.
-- tools are only as good as the hands that hold them https://www.custommade.com/by/emeraldcrafts/
View crank49's profile
crank49
4032 posts in 2998 days
#6 posted 07-01-2015 04:31 AM
Only way I would think it would have a chance is to glue it up with contact cement or possibily epoxy.
Got to have something with a little give.
But, really, it sounds like a bad idea bottom line.
Make it out of plywood or MDF wiith some good veneer on top.
WOODIE1
#7 posted 07-01-2015 04:37 AM
To be clear I am not building anything I saw them doing it and it just looked odd.
The boards appear to be at least 8/4. The finished top was easily 2 1/2” thick.
They routed splines to join the boards to each other and for ease of description made two tops the same away. They then glued the two tops together with what I saw as running perpendicular to each other.
It is actually a good show with hardly any drama and an insight into the world of multi million dollar renovations in NYC. I am a bit surprised when he mentions $100k worth of cabinets that are painted and use MDF. Then again I am sure there are huge operating costs.
Back to the table is there a way to create a thicker top from using thinner boards??
View Aj2's profile
Aj2
#8 posted 07-01-2015 05:36 AM
You can glue as many thin boards together as you want just keep the grain running in the same direction.Its not as easy as you may think.All the pieces need to be milled flat,If you were gluing the faces tI each other.A flat assembly table good wide planer or sander.Even spreading the right amount of glue that can be squeezed out by clamps must be considered.
Or you could just screw and glue the boards together like a barn door and call it good.
-- Aj
View Woodknack's profile
Woodknack
11808 posts in 2407 days
#9 posted 07-01-2015 07:47 AM
That’s pretty much the woodworking I would expect from a typical contractor. Won’t matter anyway, the owner will be tossing it in 3-5 years for a new one.
View rwe2156's profile
rwe2156
2967 posts in 1508 days
#10 posted 07-01-2015 10:03 AM
It doesn’t follow sound ww’ing theory but that doesn’t necessarily mean its gonna fall apart.
Like Rick said, things like that aren’t build with the idea of being around 100 years later.
As far as making a thicker top, sure, you can laminate thinner boards together to make a “beam” so to speak.
Same principle as when we glue up stock to make thick legs.
I would think for wider boards you want them a) dried to the same MC and b) jointed nice and flat.
Sir Irb – I think the thin layers might be the diff with plywood. That being said, I’ve seen a Charles Neil video on the pie cupboard where he made a set of shelf rests by laminating 3 layers of wood in alternating directions.
View pintodeluxe's profile
pintodeluxe
5706 posts in 2840 days
#11 posted 07-01-2015 05:34 PM
Wood will move. There is no way around it. It doesn’t matter if you have climate control, wood will still expand and contract seasonally. When you try to stop wood from moving, that is when you get cracks and warped panels. When you account for the movement, that is when you succeed.
The only reason plywood works is because the layers are so thin.
Also, consider the width of a project. A 10-12” wide project may suffer no ill effects if you break all the rules. However a 36-60” tabletop will fail, it’s just a matter of time.
Thanks for posting, it’s good food for thought.
emart
#12 posted 07-03-2015 08:35 AM
Honestly i think the best way would be gluing planks onto layers of plywood and then using extra thick trim on the edge you can either steam bend the outer edge or make it in sections like how wagon wheels are made. this would be a lot more stable than what you saw on TV.
View gthomson's profile
gthomson
16 posts in 1154 days
#13 posted 07-03-2015 09:01 AM
This is coming from a bit of a different world, the solid surfacing world, but might trigger some thoughts also. With solid surfacing countertops (Corian, Avonite, etc…) they build up only the edges, and make it seem very thick, but it may only be thick for an inch or two in.
This is one example of how it’s done there -
http://solidsurface.com/countertop-fundamentals/edge-buildup-and-corner-treatment
In that way, maybe the grain could be done to match, and use a lot less material to do it?
Greg
-- Techie by trade, tinkerer at heart
emart
#14 posted 07-03-2015 09:10 AM
This is one example of how it s done there -
Greg
- gthomson
That is probably the best option since the table top will be lighter and more stable.
View AlaskaGuy's profile
AlaskaGuy
4211 posts in 2336 days
#15 posted 07-03-2015 06:40 PM
Maybe something here to give you some ideas. This is a build of a 3’’ think table.
what ever you do keep in mind cross grain and wood movement. Don’t follow the rules and you lose.
http://www.thewoodgal.com/
