So I came across 75 pieces of bowling alley lane (16' sections)
Forum topic by Seenforever posted 06-30-2015 02:35 AM 1438 views 0 times favorited 16 replies Add to Favorites Watch
View Seenforever's profile
Seenforever
6 posts in 1027 days
06-30-2015 02:35 AM
Topic tags/keywords: bowling alley laminate pine maple bench top
Long time lurker, first time poster..
Long story short, I came across about 70+ 16’ sections of bowling alley floor (FREE!!) and I was thinking of making some pieces out of it, namely a workbench top, coffee table, etc..
My dilemma: the pieces (laminated with nails, no glue) are NOT even remotely flat.. likely from sitting for a year in a non-climate controlled alley and then being moved outside with a skid loader.
I do not have access to a plane that will fit something this wide and I would need to do it by hand. My (probably silly) idea is to start by placing a 6-8’ section on flat ground and trying to “beat” it flatter before screwing an aluminum or steel brace to the bottom and then sanding and/or hand planing the top flat before finishing it.
Does this sound even remotely possible, or does anyone have a better idea?
Any and all help is greatly appreciated. This is the only picture I currently have, but it gives you an idea of the type of un-level surface I’m talking about.
16 replies so far
View TheDane's profile
TheDane
5399 posts in 3628 days
#1 posted 06-30-2015 02:40 AM
Do you have a router? Quite a few folks here on LJ have flattened big surfaces with a router running in a sled on rails. Haven’t done it myself, but maybe somebody on here who has can chime in.
Smitty_Cabinetshop
15280 posts in 2584 days
#2 posted 06-30-2015 02:43 AM
How thick are these sections?
View firefighterontheside's profile (online now)
17944 posts in 1822 days
#3 posted 06-30-2015 02:50 AM
My kitchen island and my workbench are made from bowling lane. Mine were just as you described, nailed together from one into the next and so on. There was also angle iron lag bolted to the bottom about every 3’. Without the angle they are quite flimsy. I would think you could pull them back to flat. There are also pretty big gaps if you remove the finish. I think most bowling lanes are map,e for the first 10-12’ and then yellow pine after that. Mine were all yellow pine. I would try and get the first 10’ so you can get the little arrows on it.
View rwe2156's profile
rwe2156
2881 posts in 1446 days
#4 posted 06-30-2015 11:24 AM
It will make a fantastic workbench or assembly table.
I attached a 3 1/2” X 3” front and back rail
You have to putting end caps and make sure you’ve got them clamped flat with cauls before you do it (how do I know this ;-). I attached them with 5” lag bolts and plugged the holes.
I flattened it with a router and sled. Check out WoodWhisper video on this.
The nails were a BIG problem for me when drilling the dogholes 3 of them had nails imbedded.
Ruined my auger bit. Had to drill with a standard twist drill and the holes messed up a little.
In retrospect, I would have taken it apart, pulled the nails and glued it together.
That way I don’t play Russian roulette with drilling holds.
I would love to drill some more holes for bench dogs but I hesistate because of the nail issue.
View dhazelton's profile
dhazelton
2755 posts in 2262 days
#5 posted 06-30-2015 12:11 PM
How warped are they. And how much flex is there? If you build a bench with stiff rails will attaching the top form underneath pull it flat without cracking? Otherwise buying a wide belt sander or doing the sled route like above is you best bet.
Seenforever
#6 posted 06-30-2015 12:47 PM
- Smitty_Cabinetshop
I havent measured them and Im currently at work but I would guess 2.5”
My kitchen island and my workbench are made from bowling lane. Mine were just as you described, nailed together from one into the next and so on. There was also angle iron lag bolted to the bottom about every 3 . Without the angle they are quite flimsy. I would think you could pull them back to flat. There are also pretty big gaps if you remove the finish. I think most bowling lanes are map,e for the first 10-12 and then yellow pine after that. Mine were all yellow pine. I would try and get the first 10 so you can get the little arrows on it.
- firefighterontheside
Yeah, these have the steel T posts holding them “flat” but they arent exactly snug what with all the skid loading and what not. I have access to so many of them that I plan on using the “arrowed” sections to do some projects with, namely my bench top and maybe a coffee table for now. The first 8-12’ (im guessing) is maple and the rest is yellow pine.
- dhazelton
If im not mistaken the laminate pieces are about 1” wide and throughout the laminate there might be between 1-2mm height difference between each piece.
Im probably going to try a little bit of everything and I would guess I’ll use the sled to smooth it all out.
Thanks guys!
View MNclone's profile
MNclone
192 posts in 1549 days
#7 posted 06-30-2015 12:48 PM
Where are you located? I want some of that!
Seenforever
#8 posted 06-30-2015 12:54 PM
I’m in Louisville, KY.
View joey502's profile
joey502
525 posts in 1483 days
#9 posted 06-30-2015 02:19 PM
What part of Louisville are you in? I live a couple miles from Taylorsville lake. I also may be interested in buying one of them if you are selling.
View Bill White's profile
Bill White
4903 posts in 3926 days
#10 posted 06-30-2015 02:46 PM
My bench is from alley material. I added angle iron strips to the underside to flatten the top. Been holding well for over 20 years. Those nails are hardened spiral steel. You can bet that they are a bear to remove.
Some holes are drilled through for the holdfasts, others a just deep enough for the dogs (the “plastic” ones from a B & D Workmate).
I’ll never wear this puppy out.
Bill
-- bill@magraphics.us
Seenforever
#11 posted 06-30-2015 02:58 PM
I hadn’t thought about selling them but after looking around I’ve seen shorter sections selling for $300.
Since ours are “weathered” a bit, how does $150 per 16’ slab sound?
I have read that the pine sections are heart pine, take that for whatever value you want. Google isn’t always right.
Also, we have them stored just off Taylorsville Lake rd, so we’re very close ;)
View AlaskaGuy's profile
AlaskaGuy
4045 posts in 2274 days
#12 posted 06-30-2015 05:32 PM
I hadn t thought about selling them but after looking around I ve seen shorter sections selling for $300.
Since ours are “weathered” a bit, how does $150 per 16 slab sound?
I have read that the pine sections are heart pine, take that for whatever value you want. Google isn t always right.
Also, we have them stored just off Taylorsville Lake rd, so we re very close ;)
- Seenforever
Does that include shipping?
Seenforever
#13 posted 06-30-2015 05:33 PM
- AlaskaGuy
Hahahahaha. Tell me another one ;)
AlaskaGuy
#14 posted 06-30-2015 05:37 PM
- AlaskaGuy
- Seenforever
Actually I’d never let something with that much metal in it near my tools.
Seenforever
#15 posted 06-30-2015 05:55 PM
Actually I d never let something with that much metal in it near my tools.
- AlaskaGuy
Duly noted
(also, my “haha” reply wasnt meant to be obnoxious, I just assumed you knew how improbable shipping was and you were being sarcastic)
