| Forum topic by scottishrose | posted 53 days ago | 551 views | 0 times favorited | 22 replies | ![]() |
53 days ago |
I’m taking a class in woodworking and being a bit miffed is putting it mildly. (I just got home and it wasn’t a good day. I don’t want this class to be a complete waste of time as it cost quite a bit, and I havn’t even had the chance to change a router bit yet. I am quite disappointed that the insturctor has been running aroung setting everything up for us, so we don’t get the chance to learn how to set thing up for ourselves except to watch him do it which is not the same as doing it yourself.
Any suggestions would be helpful. |
53 days ago |
I feel for you. A instructor is suppose to instruct and not do. He souldn’t have touched your wood and stain. If he wants to show a process it should be done on his own wood. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
53 days ago |
some glues you can heat up , -- david ,new mexico ,allheart |
53 days ago |
Fire your instructor. |
53 days ago |
Wow, I can hardly believe that story. I would have exclaimed “what the heck are you doing???”. I wish I could answer. I guess the glue joint is too good to be tapped out? |
53 days ago |
patron is right, todays glues are almost to good, if you try to take it apart you will probably destroy it. i would just make one more panel and finish it the way you want. i hate to ask, but i am in school also but where are you taking classes? -- Roper - Master of sawdust- |
53 days ago |
when he tells you to submit your project tell him you never built one he did…..or put his name on the project and hand it in…we did that in trade school whenever our teacher liked to takeover projects -- Good, better, best; Never let it rest until your good is better and your better best! Mark, Windsor, Ontario |
53 days ago |
Put it in a freezer for a day. The few times I have left something accidentally in my trailer during the winter, the glue joints gave way with just a little bit of pressure on them. If you will notice on the glue instructions of most bottles, it says “Do not freeze”. There is a reason for that. -- I don't make mistakes, only design changes....www.dgmwoodworks.com |
53 days ago |
I can’t offer a suggestion about the joint, but I can offer some on the instructor. When the class is over, you will almost certainly be asked to do some sort of evaluation of the class. You should write a very poor review of the class and the instructor in particular. I had a similar situation in a week long class I took a few years back and the organization that ran it invited me back for another class, of my choice, anywhere in the U.S., for free as an apology. I suggest that your statement be polite, but don’t pull any punches. People pay an awful lot of money to take the classes and the people profiting from them don’t want you telling folks to avoid them. Good luck!! -- Dave, Colonie, NY |
53 days ago |
steam it… should soften it up, you may have to do some sanding because the steam will swell the wood at that area… but I have used a clothes steamer to soften regular yellow glue… maybe I was just luckey |
53 days ago |
Scott – I’m sorry you are having such a bad time with your class. People take classes to learn – to do – not to watch alone. There is a fair bit of watching to be expected – but sounds like your instructor is well out-of-bounds. I’m with Dave – when the class is over write a review that honestly says what went wrong. If the school is worth anything at all – they’ll do something to make it right for you. good luck. -- You can't get a hug from Facebook. |
53 days ago |
Thanks Every one! |
53 days ago |
yeah, i’d try steaming it. not sure about the glues normally used for instruments, but the way they get acoustic guitars apart for repair is steaming. |
53 days ago |
I don’t know if your instructor used Titebond, which is a popular yellow glue, but this is what Titebond’s site says about this: The key to the disassembly of glue joints is weakening the bond. For Titebond Original and Titebond II, raising the glue joint temperature with a heat gun or a blow dryer will reduce the glue’s strength. Steam from an iron may also work for Titebond Original. Placing a few drops of water on the edge of a joint made with Titebond Liquid Hide Glue will, after absorbed, cause the joint to weaken. -- Matt - Syracuse, NY |
53 days ago |
We’ve got a build a shaker table this weekend at our woodworking club. Cost 85.00 That includes all materials. Wish we could have you join us. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
53 days ago |
Get your money back and report the instructor, what he did was wrong and disrespectful to you and I am sure the school (unless he is the owner) will not support his actions. Also remind him that you reach about 11 000 woodworkers on this site alone he may apologise lol. -- All bleeding will eventually stop. |
53 days ago |
Hey everyone! |
53 days ago |
If your getting something out of the class then good, but remember it is still your time and money you are investing and maybe some constructive criticism is what maybe in order. A letter to the store manager stating your concerns and a critique of the instructor included. Never tell a LJ that something is too difficult, we’ll just try harder. I wonder, could one modify a Toby to run a 8 foot PVC steamer tube to bend wood??? -- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time |
53 days ago |
You might try using a heat gun on each joint, because the glue will soften with heat. You should be careful, & not scorch it though. Even a clothes iron should work for you. -- -** You are never to old to set another goal or to dream a new dream ****************** Dick, & Barb Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1 |
53 days ago |
I have used white vinegar to open a glued joint. I just put the vinegar heavely across the joint and let it seep in. Give it an hour or two and try to remove the joint. It may take several applications, but this method has worked for me. My first time was also with a rail and stile. The vinegar didn’t have any adverse effect on the wood as it later took the satin without problems. Good luck pkennedy -- P Kennedy Crossville, TN |
52 days ago |
glue joint update: Last night after getting the stile off, I put the whole thing between two pieces of 3/4” ply and used all the clamps I could find – which in this case C-clamps were a help. This morning I unclamped and the completely warped door was flat, I could get the panel out, and it looked mostly undamaged. I hope I can get it sanded without sanding off the detail, get the grain filler on effectively on all those angles and then get a good french polish on all the parts. Since I’m all set up to sharpen the chisels that were my grandfather’s – at least the hand part of the sharpening, have a brand new Work Sharp which came with a handy DVD, and I attended a sharpening class, I really don’t anticipate having any real difficulties making the mortises for the henges which the teacher told me would take about 8 hours to do. That seems quite a bit of an overstatement designed to get me to buy a new set of henges like the ones he has on his cabinet, but neglected to tell me to buy.
His henges make the door sit proud of the cabinet enough so it’s noticable, which on a small cabinet makes quite a big difference. Maybe on a kitchen cabinet door it would not be noticed, but on a small project things need to look better as people look closer to the details on a smaller pieces. Since I’m looking at this project as a learning tool first and not expecting perfect outcomes, I don’t care if the mortises are perfect. They might be and that would be great, then if they aren’t, I’ll find out or figure out for myself how to do it better next time. My 11 year old niece was here last night when I came in very upset about the project and typed the first request for help. I told her I would have help soon. She came back a few minutes later as I was opening up my e-mail account and I showed her the list of responses from LJ’s. She just stood there wide eyed and said “Dang!” |
52 days ago |
There is a lot involved with wood working. Maybe a big lesson for you would be that being unhappy with how an unfinish project looks is normal. It is really hard to know how a board will look finished. |
52 days ago |
your perseverance is impressive . you are destined to become a great composer ! -- david ,new mexico ,allheart |
| Forum | Topics |
Woodworking Skill Share
2898 |
3913 |
255 |
941 |
221 |
Woodworking Trade & Swap
616 |
Coffee Lounge
2368 |
LumberJocks.com Site Feedback
522 |
