Delta 36-725 contractor saw questions
Forum topic by jvallee posted 06-28-2015 06:20 PM 1705 views 0 times favorited 7 replies Add to Favorites Watch
View jvallee's profile
jvallee
14 posts in 1548 days
06-28-2015 06:20 PM
I have purchased the Delta 36-725 and am very disappointed. Poor fitting when assembling, received wrong answers from pre-sales support (both add-ons I purchased from Delta do NOT fit this saw). Tech support post sale was no help.
I am making it work BUT today, it stopped as I had a piece of lumber next to the blade when I turned it on.
Checked circuit breaker etc etc etc. The manual says it has a reset button but I’ll be darned it I can figure out where it is according to the diagram.
Can anyone properly describe where the reset button is? I’m dead in the water until I find it.
7 replies so far
View TheFridge's profile
TheFridge
10816 posts in 1723 days
#1 posted 06-28-2015 06:22 PM
Usually on the motor itself prob.
View MrUnix's profile
MrUnix
7106 posts in 2436 days
#2 posted 06-28-2015 06:28 PM
Manual sez it’s on the power switch. Should be fairly obvious (they usually don’t hide them!). Make sure you are getting power at the outlet first and then trace it back. Cheap multimeter is you friend.
jvallee
#3 posted 06-28-2015 06:32 PM
Not on power switch. The diagram show it on the underside of something (not power switch box)?? Anyone actually have one and can tell me where it is?
MrUnix
#4 posted 06-28-2015 06:47 PM
- jvallee
LOL – The troubleshooting section says it’s on the switch, but the section on ‘overload protection’ says it’s on the motor like TheFridge suggested…
Looks like you gotta get up under the saw to the motor.
View Woodknack's profile
Woodknack
12464 posts in 2617 days
#5 posted 06-29-2015 07:57 AM
This is your guy for that saw—
http://lumberjocks.com/reviews/3822
jvallee
#6 posted 06-29-2015 02:59 PM
Rick M, I did read his review before and after buying. Helped a lot!
I ended up calling tech support. To find it, do one of 2 things:
1) lie on floor and look up under saw or
2) look thru dust port to see it.
Neither answer looked anything like the manual!!!
Woodknack
#7 posted 07-01-2015 08:08 AM
The manual says the button is on the motor under the saw. Figure B is pointing underneath the saw. It’s a terrible diagram but they probably assumed that most people could read and find the motor without a picture.
If you still can’t find the motor or button, go to that thread I posted and ask those guys.
