Just bought an Intellicarve 1013 - need help getting started
« back to CNC Woodworking forum
Forum topic by soccer2010 posted 06-28-2015 05:56 PM 988 views 0 times favorited 4 replies Add to Favorites Watch
View soccer2010's profile
soccer2010
121 posts in 2394 days
06-28-2015 05:56 PM
Topic tags/keywords: cnc woodcarving intellicarve
I just bought one that was a little used and not sure where to start. I have a macbook at home and as I understand, it’s not compatible with the included i-picture. Ideas for software? First I”m looking to make letters/words and straight line cuts. Then I want to start carving from grayscale photographs. What bits and where to get them?
-- John
View bruc101's profile
bruc101
1200 posts in 3506 days
#1 posted 06-28-2015 09:01 PM
I’ve got a friend that had one of those and I think he used Coreldraw. If that will work for you let me know your OS on a pc. I’ve got some extra copies of Coreldraw 12. I use versions 9 – 14 to lay out signs to carve and route for customers. You can see some of the letters and layouts on my free plans site under signs.
http://plans.sawmillvalley.org/signs.html
-- Bruce Free Plans http://plans.sawmillvalley.org
soccer2010
#2 posted 06-28-2015 09:53 PM
I’m running OS X 10.8.5 on my macbook. I’ll be starting up a windows machine next weekend. Thanks for any help and I’m going to check out your website now.
-- John
bruc101
#3 posted 06-28-2015 10:43 PM
I run Coreldraw 12 and X4 on Windows 7. I think anything above that and you would need a later version. Not to bad a price for it on ebay. Windows 7 is as far as I have plans to go. I also use a 2000pro and an xp machine. I refuse to spend 1000’s of dollars upgrading my software chasing new windows versions.
If you can use Coreldraw 12 I should be able to dig up a copy and send it to you. I think we bought seven copies and only used 6 of them. All my daughters are using 9 – x4 and have no plans to upgrade either.
Youtube is your friend when learning Coreldraw.
soccer2010
#4 posted 06-29-2015 06:27 AM
Bruce, I sent you a PM.
-- John
