DeWalt Drill Wobble Fix?
Forum topic by Dean_Morrell posted 09-30-2009 01:02 AM 9704 views 0 times favorited 3 replies Add to Favorites Watch
View Dean_Morrell's profile
Dean_Morrell
41 posts in 3394 days
09-30-2009 01:02 AM
Topic tags/keywords: drill wobble
I have a 14.4v DeWalt XRP with keyless chuck that has served me well for over 5 years. Some time ago I used it to mix up some thinset – a job just on the edge of the drills ability. Since then, anything chucked into the drill is slightly off center. It wobbles, as does the whole chuck.
I have removed the chuck from the drill and inspected it. All appears to be fine, but I doubt I’d be able to judge by eye the fault.
Any ideas on how to fix this? What else can I try?
-- Worry does not empty tomorrow of it's sorrow, it empties today of it's strength.
3 replies so far
View papadan's profile
papadan
3584 posts in 3566 days
#1 posted 09-30-2009 01:24 AM
Remove the chuck again and run the drill by itself, you my need to stick something like an ice pick to the end and see if it wobbles. If the shaft wobbles, I would say it is time for a new drill. That old probably isn’t worth the cost(if available) of a new output shaft. If it does not wobble, buy a new chuck for it.
View lew's profile
lew
12424 posts in 3953 days
#2 posted 09-30-2009 01:25 AM
If the entire chuck wobbles, sounds like either the bearing at the front of the drill is bad or maybe the shaft (thru the bearing) got bent.
Dean_Morrell
#3 posted 09-30-2009 01:42 AM
Gak! Replacing the drill wasn’t on my radar. But that tip to test the drive shaft is a good one. Perhaps there’s time yet tonight. Thanks papadan!
