Glue Blob Problems
Forum topic by PeteCollin posted 06-28-2015 03:58 PM 1518 views 0 times favorited 17 replies Add to Favorites Watch
View PeteCollin's profile
PeteCollin
60 posts in 1296 days
06-28-2015 03:58 PM
Topic tags/keywords: question
Hello All,
I have a persistent problem that i need to get around. When gluing projects, no matter how carefully I try to clean the excess glue off, there will be blobs left behind on the project. I can’t see them, because it is usually a thin sheen of glue on the wood. But when i go to put the stain or varnish on, it is revealed like hotel sheets under a black light. This is painstaking to treat after the fact. I have to wait for the finish to dry, go back and sand, and i’m not even sure if I got it all! I tried finishing the pieces before the assembly, but with my Windsor chairs, you must do some sanding and finishing AFTER you mount the legs, and this makes for inconsistency in the color afterwards. There must be some efficient way of dealing with this that I haven’t learned about or thought of. Can anybody offer advice?
Pete Collin
17 replies so far
View Nubsnstubs's profile
Nubsnstubs
1286 posts in 1724 days
#1 posted 06-28-2015 04:31 PM
When I have glue run out, I do not wipe it off. After it’s cured, I either peel it off, or use a chisel/scraper to remove the glue.
When I had my business going and had employees, I had to explain to them every day, “Do not wipe wet glue off the wood. Remove it after it has dried.” When glue is either wiped off with a finger or washed off with a wet rag, the final finish is going to be a lot worse than removing the glue when it’s dry…........... Jerry (in Tucson)
View DIYaholic's profile
DIYaholic
19618 posts in 2669 days
#2 posted 06-28-2015 04:40 PM
You can wipe down the project with mineral spirits….
To reveal the offending glue blobs, prior to applying the finish.
View Ripthorn's profile
Ripthorn
1458 posts in 2979 days
#3 posted 06-28-2015 05:02 PM
Another thing you can do is put masking tape on both sides of the seam. Or you can wipe the still wet glue with a damp rag, or clean it with a chisel/scraper/plane afterwards. I use naphtha to check for any residual glue prior to finishing.
View Oldtool's profile
Oldtool
2619 posts in 2185 days
#4 posted 06-28-2015 06:16 PM
Pete,
I am most definitely not an expert, so in my amateurs experience I’ve always wiped off excess glue with a very damp cloth, without any problems to date.
I know experts say not to do this because it smears the glue and water could seep into the joint & weaken it, but so far all my projects have held together, and applying dye hasn’t been a problem.
Having said that, I should also inform you that I have always used Titebond glue, therefore this is what my experiencd is based on.
Hope this helps.
-- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln
View bondogaposis's profile
bondogaposis
4719 posts in 2345 days
#5 posted 06-28-2015 06:46 PM
Prevention is the best cure, try using the less glue to begin with and apply it w/ more care. Having said that I know the problem can’t be completely eliminated, so the above suggestions are good ones.
-- Bondo Gaposis
View AlaskaGuy's profile
AlaskaGuy
4121 posts in 2303 days
#6 posted 06-28-2015 06:57 PM
Prevention is the best cure, try using the less glue to begin with and apply it w/ more care. Having said that I know the problem can t be completely eliminated, so the above suggestions are good ones.
- bondogaposis
Yep, use less glue.
When I have glue run out, I do not wipe it off. After it s cured, I either peel it off, or use a chisel/scraper to remove the glue.
When I had my business going and had employees, I had to explain to them every day, “Do not wipe wet glue off the wood. Remove it after it has dried.” When glue is either wiped off with a finger or washed off with a wet rag, the final finish is going to be a lot worse than removing the glue when it s dry…........... Jerry (in Tucson)
- Nubsnstubs
Yep, don’t wipe, peel it off after an hour or so.
- DIYaholic
Yep, this will make it show up.
View Daruc's profile
Daruc
460 posts in 1127 days
#7 posted 06-28-2015 07:01 PM
I been wiping glue with a wet rag for my whole career with no problems. (over 25 years)
Be sure to keep the rag clean and rinsed, and get all the glue off. Sand the wiped spot ,after it dries, with the same final grit you use on the rest of the project before you finish. I Never see glue spots after staining.
I’ve heard arguments for both sides, but my own experience proves it to be positive.
View AandCstyle's profile
AandCstyle
3050 posts in 2251 days
#8 posted 06-28-2015 09:07 PM
Pete, you can also apply wax (Johnson’s Paste Wax) to the areas adjacent to the glue surfaces. The glue won’t stick to the wax. Once the joint has dried/cured, remove the wax with naphtha. This is a little better than taping because glue can get under the tape. HTH
-- Art
View shipwright's profile
shipwright
7980 posts in 2792 days
#9 posted 06-29-2015 12:02 AM
Of course you could use hide glue which (among its other advantages) does not interfere with finish.
View DKV's profile
DKV
3940 posts in 2498 days
#10 posted 06-29-2015 12:10 AM
View TheGreatJon's profile
TheGreatJon
337 posts in 1228 days
#11 posted 06-29-2015 12:28 AM
While I don’t really have any constructive advise, I just wanted to throw out that you’re not alone in this issue. Thanks for posting about it. I learned a few things here.
-- This is not the signature line you are looking for.
PeteCollin
#12 posted 06-29-2015 12:38 AM
Thank you everyone for the advice. it’s too late for the chair I am currently finishing, but the next windsor chair should be better.
View timbertailor's profile
timbertailor
1594 posts in 1418 days
#13 posted 06-29-2015 01:42 PM
I ve heard arguments for both sides, but my own experience proves it to be positive.
- woodust
I do the same thing. Water tends to raise the grain so it will need to be sanded if you use a wet rag. You learn to be sparing with the wet rag and the glue, after your first staining nightmare.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2364 days
#14 posted 06-29-2015 03:04 PM
I used to wipe off with a damp rag, but now I’m in the “wait an hour and peel it off” camp. Less work, and at that point you can take off a clamp if its in the way.
If I forget to go back after an hour, I go at it with a card scraper, or a chisel if it’s in a corner. Usually while I’m doing that, I’m wishing I had remembered to go back out after an hour.
View distrbd's profile
distrbd
2252 posts in 2440 days
#15 posted 06-29-2015 03:54 PM
I used to let the glue dry and then remove or scrape it but stopped doing that because in porous or soft wood like pine, the areas that were scraped clean still absorbed dyes less than the rest of the wood although it looked perfectly clean before the dye application.
I now use a wet rag to completely wipe the glue,keep using fresh rags until there’s no residue left.
-- Ken from Ontario, Canada
