pre-carter student
« back to Hand Tools forum
Forum topic by daddywoofdawg posted 06-28-2015 02:41 PM 2692 views 0 times favorited 131 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1809 days
06-28-2015 02:41 PM
I was in school before jimmy carter tried to make the us metric,but do to the internet I’m finding more metric measurements;So I’m going to get a tape with metric on it.
Here is my question,In the photo is the big red numbers on the bottom MM or CM? ,is the small marks on the bottom then one MM each?
131 replies so far
View lateralus819's profile
lateralus819
2241 posts in 2124 days
#1 posted 06-28-2015 02:46 PM
The large numbers are CM yes. The small dashes are MM.
View johnstoneb's profile
johnstoneb
3070 posts in 2407 days
#2 posted 06-28-2015 02:46 PM
there are 10 mm to a cm. The numbers are centimeters.
The metric system is based on tens
1000 mm to a meter
10mm to a cm
100 cm to a meter
A rough conversion approximately 2.5 cm to an inch.
-- Bruce, Boise, ID
View MarcusM's profile
MarcusM
57 posts in 3214 days
#3 posted 06-28-2015 02:48 PM
The red is CM, the black is MM.
-- Tilbilly Mark
View Texcaster's profile
Texcaster
1286 posts in 1908 days
#4 posted 06-28-2015 03:22 PM
Most of the trades in Australia work in mm. and / or metres, cm. are not used.
Ex : a kitchen benchtop is 900mm high, a passage door is 2100mm or 2.1m. high. Dual metric / imperial tapes can’t be read from both sides. Timber is sold by the cube or M3
My wife used to be in the rag trade, she works in cm. We have a hard time communicating sometimes.
-- Mama calls me Texcaster but my real name is Mr. Earl.
View KeithP's profile
KeithP
15 posts in 1472 days
#5 posted 06-28-2015 05:06 PM
Yes. Big red numbers are centimeters (cm), each small rule mark is a millimeter (mm).
The conversion rate is 2.54 cm:inch, aka 25.4mm:inch.
View JoeinGa's profile
JoeinGa
7739 posts in 2241 days
#6 posted 06-28-2015 05:15 PM
So daddywoofdawg … Next time you’re calling out cutting measurements to somebody, you can holler
“Hey! Cut the next one 600 centimeters plus 4 of the little tiny marks!”
View Beams37's profile
Beams37
166 posts in 1424 days
#7 posted 06-28-2015 05:16 PM
As a vet, I learned a lot about the metric system in the military. I know this isn’t what you asked, but it is an amazingly easy system of measurement.
On a side note, where did you get the tape with both? I like that!
-- FNG ... On a quest for knowledge.
View Yonak's profile
Yonak
986 posts in 1755 days
#8 posted 06-28-2015 07:41 PM
..Now, if only we could somehow get to a base 12 number system all would be rosy.
View TheDane's profile
TheDane
5574 posts in 3897 days
#9 posted 06-28-2015 07:52 PM
Years ago (before I got into woodworking), I opposed switching to the metric system.
Now I wish we had!
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1257 posts in 1947 days
#10 posted 06-28-2015 08:17 PM
For the qurious here some more information: https://en.wikipedia.org/wiki/Metre
-- "Do or Do not. There is no try." - Yoda
View robscastle's profile
robscastle
5626 posts in 2438 days
#11 posted 06-28-2015 08:53 PM
From an Australian point of view.
The metric system (SI) was a great idea and upon its introduction cm were not prefered values.
However obviously nobody tried selling that or maybe even asking/telling that to the textile industry and “other” trades.
Once the metric system was introduced commissioned and set to work the board was disbanded and hence the cm were no longer a non prefered sub unit.
The USA being the USA did their own thing, and I guess will always do so (no ill intent infered here by the way)
I use the metric system in preference to the imperial system but have to by way of necessity and need of accuracy to be able to relate to both.
When I did my Engineering Metrology certificate it was all in metric however historicial measurements like the cubit, foot and inch etc were part of the course.
When you study atomic clocks and interferometry in measurement it all falls into place, you just have to keep your wits about you.
As for tape measures well they are back to front as well, we by way of convention read left to right, but try measuring that way!!
If you think thats all too confusing just wait until the introduction of metric time!
I think I hear my Table Saw calling !!
-- Regards Rob
View SirIrb's profile
SirIrb
1239 posts in 1465 days
#12 posted 06-28-2015 08:58 PM
I was in first grade after JC. So of course they taught standard and metric side by side. My dad almost killed me when I said something about a 16mm wrench. Because of the side by side learning I always thought of a cm as about a half inch. Thanks public education, you’re a bunch of jack holes. Yes, haha, I married a teacher. Yes, haha, she thinks quite the same as me.
View BubbaIBA's profile
BubbaIBA
387 posts in 2611 days
#13 posted 06-28-2015 09:21 PM
Several years ago I converted my shop from imperial to metric. It was one of the smartest moves I’ve made in my shop. Measurement mistakes seldom happen when working metric and once you are use to thinking in metric there is much less time spent butt scratching and re-measuring.
The “yellow” FastCap ProCarpenter 16’ tape is Metric/Standard (FastCap’s term). It is a very good tape and can be handy during the transition from thinking imperial to thinking metric.
View distrbd's profile
distrbd
2252 posts in 2680 days
#14 posted 06-28-2015 10:58 PM
Order your measuring tools from Canada,the funny thing is I order all my rules from the US , I like both sides in imperial system not half in cm and half in inches.
-- Ken from Ontario, Canada
View BurlyBob's profile
BurlyBob
6029 posts in 2500 days
#15 posted 06-28-2015 11:30 PM
I was totally turned off by this thread when you mentioned Jimmy Carter. What a total waste. Thankfully Ronald Reagan saved the country till Obama came on the scene.
showing 1 through 15 of 131 replies
