Lock in dye with spray shellac before wiping on water based finish?
Forum topic by jimmy J posted 06-28-2015 12:20 PM 784 views 0 times favorited 7 replies Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2348 days
06-28-2015 12:20 PM
So I’ve dyed my table legs with transtint. On the sample boards I’ve made, when I wipe on the Enduro var finish, I tend to get the dye to run a bit. Is it OK to use the non wax shellac can spray before wiping the Enduro?I’ve never used a can spray. How much spray to actually out on?
7 replies so far
4956 posts in 2463 days
#1 posted 06-28-2015 01:24 PM
It absolutely is (and recommended by many). Transtint will dissolve in water and the moisture in the Enduro var is re-dissolving it and causing the streaks. The shellac will seal it form the moisture…..I suggest de waxed shellac (Seal Coat) since the wax can cause problems sometimes with waterborne top coats.
View conifur's profile
conifur
955 posts in 1121 days
#2 posted 06-28-2015 01:35 PM
Transtint will also redissolve in alcohol which is the medium in shellac. What I do is use a oil base poly cut to 50% with thinner as a coat over the dyed wood to seal the dye. Then finish with what ever.
117063 posts in 3547 days
#3 posted 06-28-2015 01:59 PM
Good advice
If you have the means to spray it with shellac then you won’t have the lift you can have by brushing it on. If you don’t have a spray gun Harbor freight sells guns that work fine for a low cost,of course that means you need a compresser that will deliver enough air volume to spray with.Just like you did before first practice spraying say water on some cardboard or on an unimportant piece of plywood then try the Shellac on a sample piece of wood.
http://www.harborfreight.com/20-oz-high-volume-low-pressure-gravity-feed-spray-gun-47016.html
#4 posted 06-28-2015 02:24 PM
Good point, it will dissolve in alcohol as well, the shellac needs to be sprayed.
jimmy J
#5 posted 06-28-2015 02:52 PM
Great. Thank youyou. I purchased a can of the zinnser (sp) areasol so will try that. Assume a light coat will do?
View Bill White's profile
Bill White
4910 posts in 3930 days
#6 posted 06-28-2015 03:12 PM
Be sure it is the SEAL COAT Zinsser.
Bill
-- bill@magraphics.us
#7 posted 06-28-2015 03:31 PM
You’re just trying to seal it from the water, so the light coat (but it has to be 100% coated) should do.
