Clamping Question
Forum topic by woodtablet posted 06-28-2015 06:43 AM 1031 views 0 times favorited 12 replies Add to Favorites Watch
View woodtablet's profile
woodtablet
31 posts in 1481 days
06-28-2015 06:43 AM
Topic tags/keywords: question
I am making a miniature table for my 2.5 year old daughter, so she can “cook” with me in the kitchen. Its about 20” inches tall, and she really loves being in the kitchen with me.
When making this table, I had a bit of problem, that I hope someone can help me with for future projects.
So in my awesome diagram, I have a table top, and a table leg. The issue is when I clamp the leg, the clamp pulls the leg out of square because I dont have the legs at the corner / edge of the table top. The clamp pulls the leg towards it and down.
In the second picture you can see how I tried to compensate, by clamping in diagonal and bungee pull to fight the pull away.
How would you clamp this ? Or how would you construct the table to avoid this problem ?
Thanks,
Woodtablet
12 replies so far
View Woodknack's profile
Woodknack
12469 posts in 2622 days
#1 posted 06-28-2015 08:04 AM
For a little table like that I would use pocket hole screws and be done with it. The reality is she will outgrow it fairly quickly. But otherwise the correct way is build a base consisting of legs and aprons then attach the top to the apron.
View Slemi's profile
Slemi
117 posts in 1783 days
#2 posted 06-28-2015 08:10 AM
Maybe like this?
View bondogaposis's profile
bondogaposis
5157 posts in 2593 days
#3 posted 06-28-2015 12:40 PM
Mortise and tenon into an apron, then attach the apron to the top. Gluing the end grain of the legs to the top like that is not going to last long.
-- Bondo Gaposis
View dhazelton's profile
dhazelton
2805 posts in 2538 days
#4 posted 06-28-2015 01:05 PM
I wouldn’t glue, I’d use a mechanical fastener so as she grows you can ‘grow’ the legs with her.
View ChefHDAN's profile
ChefHDAN
1231 posts in 3091 days
#5 posted 06-28-2015 01:11 PM
+1 rick & bondo, legs to apron top to apron
117423 posts in 3819 days
#6 posted 06-28-2015 02:16 PM
For a simple table I would agree with the idea of using mechanical fasteners,but just gluing it like you drawing shows will not work,that would be glueing end grain ,that’s a very weak joint.
http://www.rockler.com/clinch-nut-plates
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1817 days
#7 posted 06-28-2015 02:52 PM
Kreg pocket holes can be your friend.If you don’t have one,get one.
View Bill White's profile
Bill White
5149 posts in 4202 days
#8 posted 06-28-2015 03:10 PM
And she WILL climb on top of it. Trust me. I had two girl babies. :)
Bill
-- bill@magraphics.us
View Ghidrah's profile
Ghidrah
667 posts in 1464 days
#9 posted 06-28-2015 03:23 PM
1stly just gluing the legs in place is only going to bring disappointment down the road once the legs get smacked a couple times too many and pop off. Odds are it’ll take some table meat with it.
My suggestion, if you don’t want to direct screw through the table top and plug then consider dowels. If you can get a hold of a drill press make yourself a 90° drill block or 2, glue a couple 3 pieces of 3/4 hard wood to clamp or DS tape to legs and table.
I’ve used DS wood screws in the past but I’ve never been able to get a perfect line up.
-- I meant to do that!
woodtablet
#10 posted 06-29-2015 06:18 AM
I didnt mention that I have 9 dowels in each leg going into the top. This current build can take my weight, when I sit on it, so its not too shabby.
If i used pocket holes, there would be a similar problem, where the side with pocket holes would be drawn in tighter than the other sides.
I like the idea of the apron & legs together, then attach that to the top will be better for me in the future when I build larger tables. Or these clinch plates, I like the idea to be able to make this table grow with her. Oh well, next time, this puppy is glued up. lol.
Thanks everyone!
-Woodtablet
woodtablet
#11 posted 06-29-2015 06:25 AM
The last leg I “clamped” like this, and this is what it will look like.
Woodknack
#12 posted 06-29-2015 07:42 AM
I feel like if you have 9 dowels in each leg and the clamp is still pulling it crooked, you are using too much clamping pressure.
