Crown molding install
Forum topic by ShawnH posted 61 days ago 547 views 0 times favorited 14 replies Add to Favorites Watch
View ShawnH's profile
ShawnH
65 posts in 974 days
61 days ago
Anybody have any tips for installing crown molding? Not cutting, but holding it in place while installing. Any good jigs for this?
-- ShawnH "A little knowledge is a tool for disaster." Chinese porverb
View kolwdwrkr's profile (online now)
kolwdwrkr
2255 posts in 489 days
61 days ago
You can get a helper like this: http://www.tjak.com/ Or similar
View blackcherry's profile
blackcherry
731 posts in 722 days
60 days ago
Check out a web site name cut-in-crown, they sure make it easy to install. I’ve use this product now for over four years and it still amazes me. There a great demo video worth watching Shawn hope this helps…Blkcherry
View grizzman's profile
grizzman
551 posts in 202 days
60 days ago
buy the outside and inside corner piecies and you dont have to make this cuts…cut one cut and it goes flush upon the blocks…..:))...is it cheating….i dont think so..its maybe on the , i will walk on the easy way and not complicate things…...lol…....cutting crown is a pain i think…....but its just an option
-- The Grizzone
View ND2ELK's profile (online now)
ND2ELK
6226 posts in 673 days
60 days ago
Go to Cutting Crown Molding with Dewalt Miter saws. Dewalt.com
Hope this helps!
-- Mc Bridge Cabinets, Iowa
View UnionLabel's profile
UnionLabel
150 posts in 99 days
60 days ago
Don’t know how often your going to need it, but go to Toll King. They have the third hand right now for 39.00.
Simple, easy and inexpensive.
-- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time
View Kent Shepherd's profile
Kent Shepherd
840 posts in 185 days
60 days ago
I would get my son or son-in-law to help.
Or try this from FastCap—May be what UnionLabel is talking about
http://www.fastcap.com/3rdhandhd.aspx
View skeezics's profile
skeezics
199 posts in 618 days
60 days ago
I’ve run miles of it by myself. cut a guage block by bedding a piece of crown and measure the height of it bedded. make some marks on the walls with the block. partially drive a finish nail at the end away from you at the line. rest the crown on the nail and walk your end up the ladder. nail it up to your lines and stay away from the end about 4 feet. cope the next piece and cut to length. do the second piece same as the first with the nail to the other end. use the cope to fit the first and second piece at your end . the lsat piece is a double cope. cut it about 1/16”-1/8” long. bow it out in the middle and snap it in. Crown is simple once you get past the fear factor. :-}
-- hey honey! watch this!
View Mike Pousson's profile
Mike Pousson
5 posts in 88 days
60 days ago
I cut small blocks of MDF two different lengths. I brad nail the longer over the shorter. I figure out how much wall the crown molding will cover and measure that distance down from the ceiling every 6 feet. I tack my “brackets” at the mark with the longer one on the outside. I curl the molding into them and then go to the corner and start nailing. I can put 400 ft in a day by myself.
-- Mike in Waubaushene, ON
View ArtistryinWood's profile
ArtistryinWood
14 posts in 586 days
57 days ago
Try this Shawn
http://www.leevalley.com/wood/page.aspx?c=2&cat=1,43456,62045&p=62045
Andrew
-- It seem's to me i've lived my life a lot better than i think i have.
View Rogue's profile
Rogue
94 posts in 369 days
57 days ago
You Dont really need a jig. Flip that bad boy upside down. Hold the top of the crown to the bed of you saw and the back to your fince. As long as you fence is tall enough your golden. Here a tip, before putting you mitre together get a marker that is close the color of your molding or even better use the stain that you stained it with (if you have it). Color the mitres before putting it up and your joints look perfect everytime even it they aren’t.
-- Rogue
ShawnH
56 days ago
Thanks for all the great tips. I will be cutting and hanging today. Blackcherry, I ordered the cut n crown and am excited to try it out. Thanks again
View NSWoodspinner's profile
NSWoodspinner
20 posts in 35 days
31 days ago
Rogue-
You are right. I had a crown molding project handed to me a while back and, while despairing as to how I was going to do it right, happened to google “install crown molding” on Youtube. The guy in the video indicated exactly what you said, resulting in a personal “face-palm” moment. It took me about an afternoon to do two bedrooms worth of molding, with surprisingly little waste. Good idea about coloring the mitre, tho – wish I’d thought of that!
-- Gord M, Nova Scotia, Canada
17118 posts in 476 days
31 days ago
All good tips great info guys.
View huff's profile
huff
1630 posts in 184 days
31 days ago
I think I’ll call Skeezics or Mike Pousson!
-- John @ Myrtle Beach
