Dieing Q/S oak Alcohol base
Forum topic by lcurrent posted 09-28-2009 11:35 PM 1007 views 0 times favorited 3 replies Add to Favorites Watch
View lcurrent's profile
lcurrent
125 posts in 3812 days
09-28-2009 11:35 PM
Can I use oil base polyurethane over this alcohol base die ????
Thanks Larry
-- lcurrent ( It's not a mistake till you run out of wood )
3 replies so far
27250 posts in 3819 days
#1 posted 09-29-2009 12:10 AM
Yes you can. The alcohol will evaporate quickly. I would let it sit for a few hours after dying and then begom tp coat with the poly. This is very similar to putting poly over shellac, which a lot of us do as a routine part of our finishing operations.
lcurrent
#2 posted 09-29-2009 12:18 AM
Thanks Scott
Larry
View BeeJay's profile
BeeJay
71 posts in 3185 days
#3 posted 10-01-2009 01:14 PM
One of the modern methods of mimmicking antiquities is to first use an alcohol based dye and go over it with grain filler followed by an oil based stain and finished with lacquer, shellac or poly. Just be sure each is very dry first.
-- If you try to fail and succeed, what have you done?
