Planing Aluminum
Forum topic by Innovator posted 58 days ago 347 views 0 times favorited 10 replies Add to Favorites Watch
View Innovator's profile
Innovator
3125 posts in 309 days
58 days ago
Topic tags/keywords: question jointer milling
I have a piece of aluminum angle iron that is 3/8” thick x 2” x 2” and slightly out of square. I was wondering if anyone has used a jointer to square it up. Or used the jointer for aluminum at all. The jointer I have is a powermatic with carbide heads.
I have already called powermatic and they were not sure if it could be done or not.
I am assuming it is ok but I wanted to ask first if anyone has done it before I subject my machine to it.
Thanks
Rob
-- Whether You Think You Can or You Think You Can't, YOU ARE RIGHT!!!
View ondablade's profile
ondablade
68 posts in 94 days
58 days ago
My thought is that you would risk getting skewered by the piece of aluminium being kicked back, especially if as i think you are proposing to cut across a 2in wide surface. Or having the workpiece kicked out so the cutter is suddenly and unexpectedly exposed.
It’s not necessarily impossible, but at best it’d be a case of taking really light cuts (measured in thou), using pushers while standing well to one side, and proceeding very much at your own risk to self, machine and everything else!! Aluminium, specially in certain grades, has a tendency to pick up on cutters too – with the result that the reaction force suddenly increases.
I doubt you’d get anybody to stand over it from a H&S point of view….
-- Late awakener....
View treeman's profile
treeman
149 posts in 345 days
58 days ago
I think I’d be going to a machine shop for this job.
View Kindlingmaker's profile
Kindlingmaker
1471 posts in 422 days
58 days ago
ditto… MACHINE SHOP or new alum
View jack1's profile
jack1
382 posts in 923 days
58 days ago
I’ve seen aluminum pack into blades where you had to kind of chisel it out. I think I’d pass too.
-- jack -- measure once, curse twice!
TopamaxSurvivor
3035 posts in 571 days
58 days ago
And it has a tendency to gall.
View bentlyj's profile
bentlyj
786 posts in 366 days
58 days ago
I wouldn’t do it.
I would put on an aluminum blade and do it on my table saw though.
(hair at a time)
View Scott 's profile
Scott
85 posts in 255 days
58 days ago
The carbide is plenty tough enough to handle the alluminum but the machine isn’t set up to mill metals. The “blades” aren’t made to evacuate metal from the cut like spiral fluted mill tooling is so you get a build up up shavings. You would prob. not be happy with the results.
-- Scott, South Carolina
Innovator
58 days ago
OK, there seems to be a theme here…....
DON’T DO IT!!!!!!!!!!!!!!!!!
Thanks for the input, I will pass on it.
I will be able to shim it to make it square, I just dont want to worry about it going out of square.
View charlie48's profile (online now)
charlie48
43 posts in 65 days
58 days ago
depending on how out of square it is ,if you have a disc sander,make a jig to hold it and run passes untill square,if it isn’t to long.Slow but might work.
-- Only time will tell if it was time well spent
View skywalker01's profile
skywalker01
92 posts in 189 days
58 days ago
I have an old delta table top planer that I will use to plane really thin aluminum. It is great for anything smaller than an 1/8 inch wide but it beats the blade up pretty bad. It’s hard to cut even wood now because it’s so dull but I don’t use it for that anyways so I don’t care.
I wouldn’t do it. I think if you are a strong person you could keep it under control but I am almost certain that it would come out looking like crap, if it even cut into it.
Cya
-- LAS
