Hollow Grinding
Forum topic by ChunkyC posted 09-28-2009 04:19 AM 1456 views 0 times favorited 4 replies Add to Favorites Watch
View ChunkyC's profile
ChunkyC
856 posts in 3162 days
09-28-2009 04:19 AM
Being a power tool kind of guy and not much into the hand tools, I’ve not much experience with sharping tools. So …
I have a 8” bench top Wilton Grinder. Is this too big for Hollow Grinding chisels? I’ve seen videos of this being done but with much smaller grinders. I got some projects on the list that will require mortising. No doubt this will require the use of good sharp chisels.
Thanks,
Chunk
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
35100 posts in 4308 days
#1 posted 09-28-2009 04:37 AM
The purpose for the hollow grind (in my opinion) is to faculty the resharpening where you only have a small amount of metal to remove in order to get the tip sharp again.
Having an 8” grinder should not make much of a difference.
TopamaxSurvivor
18197 posts in 3583 days
#2 posted 09-28-2009 07:58 AM
The radius of the hollow grind would just be shallower or you might not be able to hardly notice it. Should still be able to sharpen just fine.
View Marc5's profile
Marc5
304 posts in 3249 days
#3 posted 09-28-2009 11:58 AM
I have a Jet wet grinder with a 10” wheel and it works fine. I agree 6, 8 10 doesn’t matter. Hollow grinding really speeds up honing either by hand or with a jig and in my case I tend to keep them sharp because it takes a minute to touch them up while in use. Good luck.
-- Marc
View stefang's profile
stefang
15784 posts in 3242 days
#4 posted 09-29-2009 10:14 PM
I have a bench grinder which of course gives a hollow grind, but frankly I think that a micro bevel that I hone onto all of my chisels mitigates the need/advantage of a hollow grind, at least from a standpoint of doing touch-up honing.
