Wood expansion
« back to Joinery forum
Forum topic by lateralus819 posted 06-26-2015 01:14 AM 899 views 0 times favorited 6 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 1796 days
06-26-2015 01:14 AM
I need to add a bottom to a box. I was thinking of using a solid wood bottom. Poplar.
Would 1/8” allowance be enough over a 12” width? Im gonna try and get a piece thats QS or close to it.
Also would I just glue one side like on drawers?
View Ghidrah's profile
Ghidrah
667 posts in 1129 days
#1 posted 06-26-2015 01:54 AM
I think it depends on the MC of the piece when its milled, if it’s high the piece will shrink more and become very sloppy. If it’s dry, low mc when cut it should be fine.
-- I meant to do that!
View jerryminer's profile
jerryminer
890 posts in 1348 days
#2 posted 06-26-2015 03:41 AM
Here is a great on-line resource for figuring shrinkage rates for various species and moisture conditions:
Shrinkulator
jerryminer
#3 posted 06-26-2015 03:44 AM
Also would I just glue one side like on drawers? – lateralus819
What? never heard of that. I don’t glue my drawer bottoms. If you want to glue, I would just glue the center area—-maybe 2-3 inches
View jdh122's profile
jdh122
983 posts in 2724 days
#4 posted 06-26-2015 06:01 AM
According to the shrinkulator, yellow poplar could vary by as much as 0.21 inches in QS and 0.38 inches in flatsawn over a 12 inch width. Seems like a lot to me, and it’s based on the guess that the woods moisture content could vary from 4 to 14% over the seasons, which seems a bit high. If it were me I’d allow for a bit more than an eighth of an inch, but as Gidrah says, it depends on the moisture conditions of the wood at the time of construction. Buiding it in the summer means that the wood is probably relatively expanded so you want to leave less room for expansion but ensure that it won’t fall out when it shrinks.
If you can get QS eastern white pine, it’ll only move by about a tenth of an inch over those same moisture content estimates.
-- Jeremy, in the Acadian forests
View SirIrb's profile
SirIrb
1239 posts in 1137 days
#5 posted 06-26-2015 11:22 AM
Why not 1/4 ply fitted into a 1/4 oversized dado?
View djwong's profile
djwong
176 posts in 3126 days
#6 posted 06-28-2015 08:31 AM
I made some 13in wide trays with 3/8in thick vertical grain douglas fir panels I glued up. I usually cut 3/16 grooves on all sides to house the panel. I allow 1/8in (more or less) clearance on all four sides. The panels I use are dry and have acclimated to my workshop for several months.
-- David W. Cupertino, CA
