Is this the dreaded dado set?
Forum topic by Octavius posted 09-28-2009 01:30 AM 1159 views 0 times favorited 5 replies Add to Favorites Watch
View Octavius's profile
Octavius
60 posts in 3195 days
09-28-2009 01:30 AM
Hi folks,
Well, I’ve more or less finished the 10” Craftsman renovation.
I’ll make a sled before any crosscuts and I need to get some sort of splitter before any rips cuts.
Meantimes, I’m planning on using a dado set to make some grooves, as in this link, step 1.
The table saw came with a 7” dado set, the one on the far left. Is this the “wobble” dado that folks warn against using?
I also have a steel 6” dado set (in the middle and on the right of the pic) – would that be a better bet?
I’m not planning on getting my fingers anywhere near the blade – was going to use that pusher, together with one of those feather boards. Is that the recommended procedure?
Cheers
5 replies so far
117113 posts in 3599 days
#1 posted 09-28-2009 01:35 AM
They work alright just not as good as stacked dado’s . Good idea about the fingers.
27250 posts in 3843 days
#2 posted 09-28-2009 01:43 AM
Yes, that is a wobble dado. But go with your stacked 6” set. You will get much better dado cuts with it. As Jim said the wobble works ok but it will not leave a flat bottom and does not have as clean a cut on the edges as a stacked set. I will confess that I had one of these. It was one of the first accessories that I bought for my Craftsman saw many years ago when I first got into woodworking. Now, however I am not sure it is still in the shop anymore since I have not seen it in years.
Keeping your fingers well away from any of your blades is a good idea. Using the feather board helps keep the stock tight to the fence and the push stick is a finger saver.
Octavius
#3 posted 09-28-2009 01:59 AM
OK, Jim and Scott, thanks. I’m hoping to give it a shot tomorrow – can’t tell you how excited I am to use this table saw.
Cheers
View ChunkyC's profile
ChunkyC
856 posts in 3276 days
#4 posted 09-28-2009 02:42 AM
I bought both of those exact dadoes new and still have them today. My wobble still hangs on the peg board today. Some people collect old planes, chisels, etc. I collect old mistakes. I haven’t used the wobble sense the late 80’s. As for the stacked, I used it a few days ago.
I’ve never had great results with the stacked dado. The bottoms are never quite flat. There is always a ridge or two on the bottom. Maybe that’s normal? I’ve never ponied up the $$ for a new stacked dado set so maybe they all do that. Make sure you keep those paper doughnuts, they’re spacers for getting the exact width of cut.
Chunk
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
View Max's profile
Max
56000 posts in 4295 days
#5 posted 09-28-2009 02:55 AM
I have a stack dado and my Dad had one that I now have. He used his quite a bit and when he had it sharpened the guy that did it asked him if he wanted it sharpened so it would cut a flat bottom and he said yes and it does cut a flat bottom. I don’t use it all that much but some.
