Craftsman plane what do i have
« back to Hand Tools forum
Forum topic by patcollins posted 06-25-2015 09:04 PM 1076 views 0 times favorited 6 replies Add to Favorites Watch
View patcollins's profile
patcollins
1687 posts in 3102 days
06-25-2015 09:04 PM
A friend gave me this, it is in good shape, anyone know what I have here?
View JayT's profile
JayT
6008 posts in 2448 days
#1 posted 06-25-2015 09:11 PM
Craftsman #5 jack plane. Looks like it was made by Millers Falls. Should make a good user once cleaned up.
-- In theory, there is no difference between theory and practice. In practice, there is.
View bandit571's profile
bandit571
21993 posts in 2921 days
#2 posted 06-25-2015 09:13 PM
A #5 Jack plane, made by Millers falls(just got a better look at the lateral lever) for Sears.
There may be a few numbers/letters stamped either on the side of the body, or at the top of the iron. Maybe a “5D BB”
patcollins
#3 posted 06-25-2015 10:30 PM
So what is a jack plane for?
View JayT's profile
JayT
#4 posted 06-25-2015 11:10 PM
#5’s are called jack planes because they are jack of all trades and can be used in almost any hand plane application, depending on how they are set up. Most people that have multiple hand planes set them up for rough work with a wide open mouth and cambered iron (radiused cutting edge). They work great in this configuration to scrub rough lumber, remove twist and cup and quickly take a board to desired dimension. Similar to how you would use a powered jointer and planer on rough lumber to get it to ready to use.
You could also sharpen the iron straight across and use it as a short jointing plane (straightening edges and flattening panels) or as smoothing plane. It’s a bit short for a lot of jointing and a bit long to be a really effective smoother, but can work for any of those. Hence, the jack of all trades, master of none.
View upchuck's profile
upchuck
540 posts in 1902 days
#5 posted 06-26-2015 03:49 AM
- patcollins
Like Bandit and JayT said it’s a Jack plane made by Millers Falls. Millers Falls made quality tools for decades during the 20th century. #5’s are probably the most common size of all the different bench planes.
- patcollins
Clean it up. Lightly lubricate all of the adjustment parts. Sharpen the blade. Then you will have a tool that will
help you remove wood in a controlled way. Planes are versatile tools and a jack plane is a versatile plane. Thank your friend.
chuck
bandit571
#6 posted 06-26-2015 04:03 AM
And..this is what they look like when restored, and working..
Millers Falls No. 14, type2.
Seems to do a decent enough job
