Surface Planning
Forum topic by MrRon posted 06-25-2015 05:25 PM 1027 views 0 times favorited 15 replies Add to Favorites Watch
View MrRon's profile
MrRon
4560 posts in 3113 days
06-25-2015 05:25 PM
Topic tags/keywords: question
I am going to re-saw pine 1/8”+thick. Can I run that through my lunchbox planer to 1/8” thickness without it breaking up?
15 replies so far
View Joshua Oehler's profile
Joshua Oehler
169 posts in 1560 days
#1 posted 06-25-2015 05:32 PM
I don’t believe I would attempt that even with some kind of sled designed for it. I would only briefly consider it if I had a helix head planer but probably still would not try it. I would be hesitant to try anything under 1/4”
-- - "But old news can change, as memories float downstream. So don't judge me by my failures, only by my dreams"
4820 posts in 2362 days
#2 posted 06-25-2015 05:42 PM
It gets a little tough because the leading edge of the thin wood isn’t stiff enough to lay flat against the lifting action of the cutterhead. If you double stick tape the leading edge down to a sled it might work, but no guarantees.
View JayT's profile
JayT
5488 posts in 2080 days
#3 posted 06-25-2015 05:59 PM
Make a hand plane thicknessing jig. Here’s one from another LJ’s projects, but there are lots of other examples out there in cyberland. Quick, easy and safe.
Click for details
View AlaskaGuy's profile
AlaskaGuy
3749 posts in 2178 days
#4 posted 06-25-2015 06:04 PM
I wouldn’t, better off with a drum sander.
View DKV's profile
DKV
3940 posts in 2373 days
#5 posted 06-25-2015 06:17 PM
I agree with Fred but I have planed a lot of pine to 1/8” on my 735 by putting a sacrificial piece up front and then sending the other pieces through butt to head without a break…
-- This is a Troll Free zone.
View nkawtg's profile
nkawtg
268 posts in 1120 days
#6 posted 06-25-2015 06:20 PM
Check out The Wood Whisperer and his recent video on planing thin strips.
https://www.youtube.com/watch?v=y0BW-dxYiBY
View DrDirt's profile
DrDirt
4418 posts in 3611 days
#7 posted 06-25-2015 09:30 PM
yes you can plane it.
I did 1/8 to make stock before I got a drum sander.
I had a piece of 1/2 inch melamine coated particle board… from one of those closet shoe organizer/shelves that are 10 bucks.
I would put a piece of doublestick Scotch tape under the ends. You only have to deal with the front edge really, base on cutter rotation.
I use the Scotch because it is very thin, so I don’t have to worry about any ghost lines like I would get with carpet tape.
Then I can just run a putty knife under the wood and it pops off the melamine surface
MrRon
#8 posted 06-26-2015 06:31 PM
Thanks for all the great input. I was thinking double stick carpet tape, but full length the wood strip. I like the planning jig which may be more appropiate for me as I will be using short strips of wood, around 12” long.
MrRon
#9 posted 06-26-2015 06:31 PM
View Kazooman's profile (online now)
Kazooman
912 posts in 1821 days
#10 posted 06-26-2015 10:21 PM
No problem. I used to own a 12” Delta planer and I ran a lot of maple stock through it to get it to the width of a saw blade kerf for projects like the chessboard tray divider shown below. No special treatment, no tape, no sled, just allowed for the customary snipe that was the norm for that machine. By the way, the divider is sitting on the “Benchtop Bench” I recently assembled. No more aching back from bending over. I will have to get the hand cut dovetail bug!
Image and video hosting by TinyPic
View rwe2156's profile
rwe2156
2746 posts in 1350 days
#11 posted 06-26-2015 10:24 PM
MrRon,
Allow me do edify a fellow ww’er.
You use a pla(1n)er to pla(1n)e wood and when your done pla(1n)ing it you start pla(2n)ing your layout and cut list. Got it?.
Pla(2n)ing is what you do when you’re trying to figure out how to sell the wife on buying a Goldwing.
Oh, and while I’m at it, its plow plane, not plough plane.
And its rabbet not rebate (we are Americans!)
Kazooman
#12 posted 06-26-2015 10:52 PM
I am getting DIZZY! I posted my response with the embedded image from my iPad. I looked at the preview and it was fine. now when I look at it on my main computer it is upside down.
I have 33 minutes of edit time left, but I think I will leave it as it is. Quite distinctive.
View johnstoneb's profile
johnstoneb
2690 posts in 2042 days
#13 posted 06-27-2015 01:52 PM
Showing your arrogance again rwe2156. It was plough before it was plow and it was rebate before it was rabbet.
Most people reading the post know what he was talking about. Even if you had to get out a dictionary to figure it out.
I have run1/8 through my DW735 without any support and it goes through just fine. That’s where my stops kick in so can’t go any thinner and don’t really want to I would be afraid of getting the cutterhead into the table.
-- Bruce, Boise, ID
rwe2156
#14 posted 06-29-2015 10:39 AM
Wow did you every miss my point.
I was referring to the British variation of the words.
It was tongue in cheek that’s what “we are American’s” mean.
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2239 days
#15 posted 06-29-2015 11:19 AM
Ron,
This weekend I was working on the legs for the table I’m building. I laminated 3/4” boards together and put a thin piece on the sides to hide the glue lines. I was planning this ash down this weekend and thought of this thread so I snapped a couple pictures.
This ash has been resawn and planed down to 3/16” without a sled or anything. No snipe, tearout, etc. Just sent through the planer (DW734 w/ stock blades). I probably could’ve gotten it to 1/8” without any problems, but I decided I wanted to do the final planning after these were glued to the leg, since I want their final thickness to be closer to 1/16”.
I think the reason I had zero problems was mindful stock selection. These pieces are pretty straight-grained, no knots, and the grain direction doesn’t change along the length of the piece.
