Bosch 1250DEVS sander
Forum topic by dbw posted 06-25-2015 11:49 AM 1057 views 0 times favorited 5 replies Add to Favorites Watch
View dbw's profile
dbw
229 posts in 1875 days
06-25-2015 11:49 AM
Topic tags/keywords: sander
I’m thinking of buying one of these. What do you folks think of this sander? Will a Festool CT26E hose work with this sander or do I have to make mods?
-- measure 3 times, cut once
5 replies so far
View ClammyBallz's profile
ClammyBallz
449 posts in 1375 days
#1 posted 06-25-2015 03:28 PM
I love mine! The dual mode is a great feature, especially if you need to do some serious sanding.
View AHuxley's profile
AHuxley
874 posts in 3560 days
#2 posted 06-26-2015 05:00 AM
The 1250 is a beast so if that is what you are looking for it is excellent. Bosch makes the 3rd best sanders (and are VERY good) behind Festool (2nd) and Mirka (1st) but only Festool makes a better sander in this format, well of the ones that are readily accessible in North America.
View dbw's profile
dbw
#3 posted 06-26-2015 11:35 AM
1) How is this sander at swirl-free finish sanding? and
2) Will a Festool CT-26E hose (27mm) work with this sander or do I have to make mods?
View dawsonbob's profile (online now)
dawsonbob
3144 posts in 1994 days
#4 posted 06-26-2015 01:07 PM
Great sander. Bosch sells a very good hose http://www.amazon.com/Bosch-VAC005-5-Meter-Vacuum-Hose/dp/B0000AV78B/ref=sr_1_1?s=hi&ie=UTF8&qid=1435323572&sr=1-1&keywords=bosch+vacuum+hose that fits perfectly. If you want the anti-static version, it’’s about twice as much. The Festool version is???
-- Mistakes are what pave the road to perfection
View Drew's profile
Drew
350 posts in 3338 days
#5 posted 06-26-2015 02:27 PM
This might be the best sander on the market. It sands better than the Festool RO 125/150 in both RO and aggressive modes, and it’s easier to handle.
The problem with this sander is durability. They just don’t hold up. The “wheel” burns out on them every 6-12 months. I had enough and switched to Festool. Probably not a good decision….
I can take a large table- say 36” x 108”- sanded to 150 in the drum sander and finish sand it up to 220 in less time with the bosch… probably 20% less time… maybe more!
-- TruCraftFurniture.com
