Plywood or boards
Forum topic by PanicButtonGuy posted 06-25-2015 02:00 AM 657 views 0 times favorited 8 replies Add to Favorites Watch
View PanicButtonGuy's profile
PanicButtonGuy
2 posts in 938 days
06-25-2015 02:00 AM
Hey there,
I’m looking to do a coffee table project and am wondering what is typically more desirable as far as the top goes. I can join boards and have seams or I can go with ply. Just wondering if there is a standard answer. I know that preference is going to play into it so a general answer is fine.
thank you in advance for your expertise!!!
8 replies so far
View TheFridge's profile
TheFridge
8646 posts in 1357 days
#1 posted 06-25-2015 02:02 AM
Depends on you really. But typically solid.
View jumbojack's profile
jumbojack
1673 posts in 2495 days
#2 posted 06-25-2015 02:32 AM
I’ve built them both ways. The solid.lumber ones look the best. The ply was OK but to a trained eye you can tell it’s ply.
View WDHLT15's profile
WDHLT15
1705 posts in 2347 days
#3 posted 06-25-2015 11:25 AM
Solid lumber for me. Plywood is for sheathing and for cabinets.
View rwe2156's profile
rwe2156
2749 posts in 1352 days
#4 posted 06-25-2015 11:57 AM
With solid wood, you can bookmatch which can create a really nice visual for a top. If you have wood with a lot of figure, the better it “pops”. But—you need sequentially cut boards and in my experience this is often not feasible when dealing with a hardwood supplier. You can also use one long board but that’s not as desirable. I’ve found a lumber mill is usually the best place to get matching wood. You can also go the veneer route, which is perfectly acceptable and a great way to get some really nice bookmatching.
Dont’ worry about seams. Its a mark of quality that proves the wood is solid and not ply.
Last but not least, if you’re building your skill set, you need to become adept at panel glue ups and get them flat anyway, so why not start with something simple like a coffee table?
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2241 days
#5 posted 06-25-2015 12:43 PM
I’d go with solid. It’ll just give the feel of (and be) higher quality. With the plywood, you’re going to have to apply an edging anyways, and the edging kind of gives it away. Plus, you can get some good lumber for substantially less per board foot than plywood costs.
View JayT's profile
JayT
5489 posts in 2082 days
#6 posted 06-25-2015 12:48 PM
I’ll echo all of the above statements. Solid wood is preferable for fine furniture, plywood is for casework or utility furniture.
Bookmatching gives a nice effect when you can do so. If you can’t get bookmatched pieces, it’s also possible with most wood species to grain match the glue-ups so that seams practically disappear. This is a good skill to learn for furniture. It takes a bit more time and usually requires a bit more waste, but the results are totally worth it. In order to keep grain consistent, you’ll want to use boards cut from the same tree, either by cutting apart one board or finding a small mill that can provide boards that were cut consecutively from the trunk.
Here’s a good video from Marc Spagnuolo that talks about and demonstrates the principle
http://www.thewoodwhisperer.com/videos/invisible-panel-joints/?as=flip%20top%20table&mode=posts&ap=1&apt=video
And here’s one my recent projects where I focused on grain matching. Each piece in the top is only 2-1/2 to 3 inches wide, but by taking the time to play with the grain lines, it was possible to make 6 individual pieces look like one seamless piece.
View DrDirt's profile
DrDirt
4418 posts in 3613 days
#7 posted 06-25-2015 12:57 PM
Solid wood.
If you were going to veneer…. then Ply or MDF
PanicButtonGuy
2 posts in 938 days
#8 posted 06-25-2015 01:48 PM
Awesome! I’ll go with solid. The main reason I’m debating is because there’s going to be a large polished concrete inlay. I thought with solid that it was going to be more difficult to cut out the shape of the inlay. I think I have it figured out now though. I’ll post a pic when it’s done. Maybe a couple weeks.
