| Forum topic by GaryK | posted 798 days ago | 1310 views | 1 time favorited | 22 replies | ![]() |
798 days ago |
796 days ago |
Hi, Gary, I don’t know much about moisture meters but I’ll kick this back to the top and see if it gets any response. -- Thos. Angle |
796 days ago |
I have a Wagners Pin-less (Not found since the move from NJ) and so I bought a Lignomat. Because I didn’t figure that I needed two of the same if I found the first one. They both seem to work great. I can’t say about the accuracy between them because I can’t use them on the same board, because I can’t find one. Mark Decou and I worked on a blog that Mark started. You might look there also. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
795 days ago |
I am also very interested in opinions on moisture meters. I see prices from $25 to well over $120. my usual rule is “bigger is better” and “you get what you pay for” but those rules have failed me in the past :) not often but enough times so that I want to do my research. -- "so much to learn and so little time".. |
795 days ago |
Well, it doesn’t look like anyone has really used on here with the exception of Karson. It looks like at this point I have decided on the Wagner L609. It’s cheaper than the Wagner MMC220 Wagner L609 – 4% to 22% $149 Wagner MMC220 – 5-to 30% $249 Anything above 22% I’m not going to deal with anyway, and that extra decimal point won’t help that much either. It’s only a half a percent difference between the two. 6.4% would equal 6% and I’ll let you know. Gary -- Gary, East TX -- The longest journey begins with a single step. |
786 days ago |
Well, I received my new meter today, and have returned it already. Very inconsistent readings. I spent about an hour testing it. The readings were just all over the place even re-testing the same piece after a while. The last straw is when I measured a couple pieces of maple from on old bowling alley lane, and it said it had 16% moisture. Probably kiln dried 20 some years ago, and air drying the rest. No way it’s going to suck up Not worth even $25. Gary -- Gary, East TX -- The longest journey begins with a single step. |
785 days ago |
So are you going to try the fancier one? -- Drew, Pleasant Grove, Utah |
709 days ago |
Hey Gary, Did you find a moisture meter that worked for you? I’m in the market for one and the price range is huge. I’m seeing prices from $20 to almost $400! |
709 days ago |
I’ve got the mmc220 on my list – kind of a dream-o-meter… Talked with a fellow yesterday that uses a Lignomat- a Portland, OR company… -- Dorje (pronounced "door-jay"), Seattle, WA |
709 days ago |
Mike – I have given up after my disappointment with my last purchase. I have gone all these years without one They all seem to be calibrated for douglas fir and you have to adjust the number given for whatever wood Gary -- Gary, East TX -- The longest journey begins with a single step. |
709 days ago |
Thanks for the update Gary. There are some that let you can pick the specie of lumber you are testing, but those are the ones that are on the expensive side. Like the one on Dorje’s wishlist, it’s one expensive unit :). |
708 days ago |
All I know is that if ya whack it with a hammer, and it spits back at ya…well, if it’s wood, then it’s too wet. If it ain’t wood, then it’s still alive and you’ve really pissed it off! Hahahahahahaha! Sorry Gary…my bad. Had to say it. The temptation, ya know? -- Bob Vila would be so proud of you! |
708 days ago |
Dadoo – I like it! -- Gary, East TX -- The longest journey begins with a single step. |
685 days ago |
Any new information on this subject, time for me to get a new one, my last low budget model took a dump. -- Ron, Twain Harte, Ca. Portable on site Sawmill Service http://westcoastlands.net/Sawmill.html http://westcoastlands.net/SawBucks2/phpBB3 http://www.portablesawmill.biz/concrete/ |
685 days ago |
Buy cheap. I think there is a saying in there someplace. I’ve got the Ligonmat and I’m happy with it. It uses wood density and moisture to figure out the % moisture. If you hit a knot the readings change. I still haven’t found my Wagner pinless one. so no comparison between them. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
683 days ago |
dang Karson I was hoping when you found it you’d offer to sell one cheap…. ???? -- CaptnA - "When someone hurts you, write it in the sand so the winds of forgiveness will scatter the memory... " |
683 days ago |
I finally decided to pick up a Delmhorst J-2000. Amazon has them for $187. Not exactly cheap, but no the most expensive one either. I did a few test readings and it seemed consistent. I’ll write a review after I have ran it through its paces. Woodworking Magazine reviewed moisture meter awhile back, I can’t remember which issue it was. I’ll have to go back and look. |
274 days ago |
I just searched eh site to find anything about moisture meteres. This is all I found. i have a Sonin combination meter that is suposed to be a combination moisture meter, stud finder, power line locator and metal finder. It doesn’t seem to do much of anything. I contacted the company, basically, they don’t care. Save your bucks. Tap the wall or use a cow magnet to find studs and metal in walls. -- Debt is nothing more than the 21st Century's form of slavery. |
274 days ago |
Lignomat has a sale going this month |
272 days ago |
I’ve got a mini ligno and I’ve been real happy with it. A friend has the Delmhorst j-lite and that seems to work well. Both are pin type MM’s. -- -JimmyC...Clayton,NC- "Just smile and wave boys, smile and wave" |
272 days ago |
JimmyC, how do you know if it’s too moist if it is off the scale? -- Debt is nothing more than the 21st Century's form of slavery. |
272 days ago |
I didn’t see any mention of the fact pinless are only for milled surfaces and won’t work of rough surfaces. I would suggest the pin type for choosing lumbr from the yard as a more practical option unless you buy milled wood. The oven dry method is an other cheap option which we use for odd species that aren’t on the chart or certain submerged lumber which picks salts and throws off the meter. We use a duo-ligno which goes from pinless to pin type but it’s for a business. -- Whatever! |
272 days ago |
I have the Lignomat E/D, it has pins, but I am very happy with it. Accuracy? I haven’t checked with another meter, but it is consistant. I just bought some kiln dried rough sawn Red Oak and they measured 6-8% mc. right where it should be. I bought mine on Ebay for $70 (including shipping) and that to me is a great deal, this unit is in excellent condition and works great. -- Doug, Cass City, Michigan |
| Forum | Topics |
Woodworking Skill Share
2926 |
3961 |
258 |
954 |
225 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
