Do I need the narrow miter slot on a router table?
Forum topic by soob posted 06-24-2015 05:49 PM 697 views 0 times favorited 3 replies Add to Favorites Watch
View soob's profile
254 posts in 1144 days
06-24-2015 05:49 PM
I recently got a cast iron router table top with two miter slots running across the front. The large (3/4”) one is fine, but the narrow one has a casting defect with about 1” of the lip missing on both sides a few inches from the left end of the slot. I marked the approximate location of the defect on the attached image. I will get a significant discount if I keep it.
My impression is that the narrow slot doesn’t really offer anything unless you already have accessories that fit it (I don’t), but am I wrong? Is there something you can only do with it that I just don’t know about? I am hoping for any input. Thanks in advance.
3 replies so far
View jerryminer's profile (online now)
910 posts in 1377 days
#1 posted 06-24-2015 06:43 PM
Can’t tell from the pic, but that slot is likely a “T” shaped slot, made for attaching hold-downs and such. You can probably avoid having to clamp in that one defective area and still get good use out of the top. I’d keep it if you’re getting a good discount
View MT_Stringer's profile
3160 posts in 3166 days
#2 posted 06-24-2015 06:53 PM
The only thing I used the slot for was to hold featherboards while I pass the stock past the cutter. I use a shop made jig (coping sled) when I cut rails and stiles for raised panels. It rides against the fence for a perfect 90 deg. cut.
Hope this helps.
But since I built a new table, it doesn’t have a slot. I made it that way because I use the table for assembly and other things. So, I made this jig to hold the featherboards.
View exelectrician's profile
2327 posts in 2362 days
#3 posted 06-24-2015 07:27 PM
Feather boards attach mostly right in front of the cutter area. Way down there on the left is a spot where you will probably never use, so yeah! Grab the discount…..
-- Love thy neighbour as thyself
