Through dovetail cross grain cuts?
Forum topic by Jeremy Hill posted 63 days ago 200 views 0 times favorited 1 reply Add to Favorites Watch
View Jeremy Hill's profile
Jeremy Hill
13 posts in 88 days
63 days ago
Topic tags/keywords: jig tip question trick padauk router joining carving
I finally had a chance to work on my writing desk and felt inspired to make the drawer’s face frame joints a through dovetails. I’ll post a pic or two when I get a chance, kinda hard to explain. But, I’m cutting the joint in two places, feeding a piece padauk 1 1/4×3/4 lengthwise through it on my router table. My tennons were already cut into either end of it, and it is/was the top face frame piece that runs the full length of the desk. When I cut them splinters went flying and it chipped out like crazy. I have one more piece of padouk to make it and am looking for pointers. Any at all would be much appreciated, Thanks.
-- Jeremy Hill
View DaveR's profile
DaveR
1527 posts in 618 days
63 days ago
Are you backing up the piece with a sacrificial board? If not, you should. Make sure it is clamped tightly. Another thing that might help is to cut out most of the waste with either a straight bit, a dado set or by hand.
If I were doing it I would start the cut on the exit side of the cut and then go to the other side and run the cut through. It’s sort of like scoring the surface. That requires great accuracy to do it right. I have the Router Boss which makes that one dead simple.
-- Until you spread your wings, you'll have no idea how far you can walk.
