Help with pore filling Spalted Maple Slab.
Forum topic by Lumberpunk posted 06-24-2015 12:40 AM 894 views 1 time favorited 3 replies Add to Favorites Watch
View Lumberpunk's profile
Lumberpunk
334 posts in 2333 days
06-24-2015 12:40 AM
Topic tags/keywords: question
Hi All, I am currently finishing a 24”x48” spalted maple slab for a coffee table using General Arm-R-Seal Semi Gloss and I am getting very high absorption on several places on the slab. I laid on 5 coats of finish and sanded it back to wood as suggested in this article:
http://www.antiquerestorers.com/Articles/SAL/filpore.htm
However I am still getting a very uneven surface and would like to figure out something a little more effective and quick. At the moment I am considering sanding it back (again) and hitting it with a coat of dewaxed shellac before the next coat of arm-r-seal or getting some CA glue but I am wondering if there are any other good options out there I should know about?
Thanks
Luke
-- If someone tells you you have enough tools and don't need any more, stop talking to them, you don't need that kind of negativity in your life.
3 replies so far
View bobasaurus's profile
bobasaurus
3444 posts in 3180 days
#1 posted 06-24-2015 01:38 AM
Dewaxed shellac does a great job at filling/sealing soft absorbent wood, I use a few coats of 1# amber on cottonwood and similar woods before moving on to waterlox or poly.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
Lumberpunk
#2 posted 06-24-2015 02:29 AM
Thanks! I have been looking at some other clear pore fillers but living in the boonies shellac is probably the best I can do on short notice.
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1173 days
#3 posted 06-24-2015 02:34 AM
Just about any finish can be used to fill pores. You can even buy pore fillers. In every case you keep applying coats and then sanding off till the pores are full. Then you can apply the top coat(s).
Amber shellac will change the color. If you want to use shellac then blonde or super blonde shellac would be a good choice and will not change the color.
