17" Grizzly Bandsaw Having Hard Time Cutting
Forum topic by Britztopher posted 06-23-2015 08:17 PM 1204 views 0 times favorited 24 replies Add to Favorites Watch
View Britztopher's profile
Britztopher
26 posts in 1299 days
06-23-2015 08:17 PM
Topic tags/keywords: bandsaw grizzly
I have a 17inch grizzly with a brand new .5 inch woodslicer blade. For some reason this setup doesnt want to cut through a 4” piece of walnut. It appears like the blade just doesnt want to enter the beginning of the wood on the cut. Almost like the blade is dull, and it doesnt want to cut. Any suggestions why this happens, and what i can do to fix it?
24 replies so far
View AZWoody's profile
AZWoody
1330 posts in 1220 days
#1 posted 06-23-2015 08:18 PM
May sound stupid but is the blade running in the right direction?
View Drew's profile
Drew
350 posts in 3096 days
#2 posted 06-23-2015 08:25 PM
Yep….. Woodslicers are sent twisted backwards.
-- TruCraftFurniture.com
Britztopher
#3 posted 06-24-2015 11:44 AM
Yes blade is in right direction, hook facing down. It cuts easily wood that is about 2.5 inches thick then halts on anything thicker. Also, another note, the walnut Im cutting is sort of green. Would it be because its still about half dry? Im just trying to remove bark from outside.
View bigblockyeti's profile
bigblockyeti
5112 posts in 1717 days
#4 posted 06-24-2015 12:01 PM
Do you have any pictures that you could post of your set up, that might help?
View conifur's profile
conifur
955 posts in 1148 days
#5 posted 06-24-2015 12:01 PM
If I remember right there was a similar post within the past week and someone mentioned there maybe some defective wood slicer band saw blades out there.
View gfadvm's profile
gfadvm
14940 posts in 2687 days
#6 posted 06-24-2015 01:00 PM
Bark is really hard on blades, particularly if it is dirty. Greener wood requires a lower TPI and deeper gullets to clear sawdust from kerf. Call Timberwolf and ask them to recommend the best blade for what you are doing. Sounds like a 1 TPI would work well.
conifur
#7 posted 06-24-2015 01:05 PM
Unless I am missing something, how can you put a BS blade on with the teeth facing up unless the teeth are facing the support bearings
View firefighterontheside's profile (online now)
18162 posts in 1853 days
#8 posted 06-24-2015 01:09 PM
The blade can be flipped inside out.
View distrbd's profile
distrbd
2252 posts in 2443 days
#9 posted 06-24-2015 01:15 PM
Please check your tires,if they are rubber, they might have stretched a bit and slip which can cause the blade to slip or cut poorly.
-- Ken from Ontario, Canada
conifur
#10 posted 06-24-2015 01:23 PM
Ah, I see said the blind man!!!!LOL Thanks, never thought about that.
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1173 days
#11 posted 06-24-2015 01:38 PM
A couple of ideas:
Try regular dry wood of the same thickness and see how it cuts. This will eliminate the question of bark and only partially dry wood. You could glue up some 2x lumber.
I had a friend cut wood with bark (and dirt) it quickly dulled my blade. Try a different blade. Order it from Highland woodworking.
Go through the Alex Snodgrass and make sure you have the bandsaw setup correctly.
Britztopher
#12 posted 06-24-2015 05:01 PM
Ill try when i get home today with dry wood. Also, i will call highland and see what would be good for cutting bark off green trees.
View Rayne's profile
Rayne
860 posts in 1536 days
#13 posted 06-24-2015 05:12 PM
Here’s a small possibility as well. Maybe the back of the blade is slightly thicker than the teeth? Unlikely, but who knows. If it is thicker, smaller wood might be o.k. to keep pushing through but with larger, that would be a problem. I’ve seen people sand down the back of the blade for smoother feed. Just a thought.
View RussellAP's profile
RussellAP
3104 posts in 2283 days
#14 posted 06-24-2015 06:23 PM
Could be saw set up. Blade tension, and rear blade bearing. If the bearing is further away from the blade than a paper width, it bends the blade causing it to enter the wood unevenly on thick stock, same can happen if the blade is too loose. Another issue could be you have a blade with 8 or more TPI which might cause it to have trouble ‘biting’ into the wood. I’d recommend a 4 TPI blade at least 3/8”. Timberwolf is a good blade.
View ElChe's profile
ElChe
630 posts in 1333 days
#15 posted 06-24-2015 07:37 PM
I’m also going to go with it’s probably the green wood as suggested above. The Woodslicer blade is very thin and has little set. It’s going to struggle with green wood.
