Using 6" Sanding Disk on 12" Sander
Forum topic by Bruce posted 06-23-2015 08:11 PM 750 views 0 times favorited 13 replies Add to Favorites Watch
View Bruce's profile
Bruce
5 posts in 1153 days
06-23-2015 08:11 PM
Topic tags/keywords: 12 sander stationery sander sanding
Hello Everyone,
I’m a new Lumberjacks member and this is my first post.
I’m thinking about getting a 12” disk sander. But I’m also thinking I might be able to use higher grit 6” sanding disks on this as well.
Is this a goofy idea? Is anyone else doing this? I don’t have a large shop and need to stretch my tool budget right now by getting tools that might be able to do double duty (i.e., 12” sander using 6” disks).
Thanks for your thoughts and comments. I’m glad to be here!
Bruce
13 replies so far
View Drew's profile
Drew
350 posts in 3184 days
#1 posted 06-23-2015 08:14 PM
That would only give you about 1-2” of sanding area.
Why wouldn’t you use 12” disk?
-- TruCraftFurniture.com
Bruce
#2 posted 06-23-2015 08:37 PM
Why wouldn t you use 12” disk?
- Drew
Hi Drew, thank you for your note. I can get 12” sanding disks up to 400 grit which I would use. But I can only find higher grits (i.e., 600, 800, etc.) in 6” sanding disks. I was thinking it would be convenient, and maybe save me from having to buy another tool, if I could use 6” sanding disks on a 12” disk sander.
I’m making small boxes. I tried sanding them with my 5” Mirka sander but it’s very awkward. So I thought having a stationery sander I could lift the piece up to might work better.
Thanks -
Bruce
View Drew's profile
Drew
#3 posted 06-23-2015 08:52 PM
Keep looking, they’re out there.
I know Klingspor has them, but you have to buy a 10 pack, and w/o an account that runs about $70
View Yonak's profile
Yonak
986 posts in 1605 days
#4 posted 06-23-2015 09:45 PM
Bruce, there’s no reason why you couldn’t do that. 6” disks would also give you the option to use them on your drill if you wanted to.
View AZWoody's profile
AZWoody
1363 posts in 1308 days
#5 posted 06-24-2015 01:08 AM
There are some people who take a 12” disc and cut out the center and place the 6” in the middle that way you have 2 grits at the same time running on the 12” disc sander.
While this may not work for you, at least, it shows that people do get enough sanding capacity from the 6” portion of the disc.
View distrbd's profile
distrbd
2252 posts in 2530 days
#6 posted 06-24-2015 01:34 PM
There’s no reason why it can’t be done but you will inevitably hit the unprotected part of the platen by hitting it or maybe gouging it , then the 12” disk may not stick properly.
-- Ken from Ontario, Canada
View conifur's profile
conifur
955 posts in 1236 days
#7 posted 06-24-2015 01:46 PM
Does this help
http://trugrit.com/index.php?main_page=index&cPath=102_16&sort=1a&perPage=25&page=2
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1260 days
#8 posted 06-24-2015 01:46 PM
Klingspor 12 inch disks up to 1200 grit. Contact them to see who sells their product in the grit you need.
View SirIrb's profile
SirIrb
1239 posts in 1315 days
#9 posted 06-24-2015 02:07 PM
+1
And they own a few WW stored in the NC area. They are the biggest (according to them) abrasive mfg on earth.
- WoodNSawdust
Bruce
#10 posted 06-24-2015 02:08 PM
Does this help
- conifur
Conifur,
Wow, thanks for the link that is excellent!!
Bruce
Bruce
#11 posted 06-24-2015 02:11 PM
- WoodNSawdust
WoodNSawdust,
Thanks for directing me to Klingpor. I swear I looked at their site before and didn’t see anything above 400 grit in a 12” disk but I just looked again and there they were. :)
I find out where the nearest retailer is.
Bruce
#12 posted 06-24-2015 02:12 PM
Much thanks to all of you who replied.
You guys are the best and I appreciate all your comments and suggestions!
Bruce
SirIrb
#13 posted 06-24-2015 02:22 PM
http://www.woodworkingshop.com/
This is my local Klingspore store in Winston Salem. Helpful. Also they have dump bins of paper if you go there.
