| Forum topic by sIKE | posted 65 days ago | 243 views | 0 times favorited | 7 replies | ![]() |
65 days ago |
Been pondering this for a bit. When Someone/plan/etc says cut a 29° bevel. I always get things stuck in my head. I use one on those digital bevel boxes so that part is easy. Where I get jumbled up is that 29° from the table which is at 0° from the blade which is at 90°. So should I zero my box on the table, then put it on the blade. Make sure it is at 90° then zero it again so it is at 0°. Then tilt the blade 29° or should I just subtract the 29° from 90° to get where I need? Which would be 61° I think that both of these are right, I am just trying to learn what others with more experience do. As an example Larry here says set you blade to 60° which would make the resulting bevel 30° correct? I love workshop math! -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
