Resawing without a bandsaw
Forum topic by jpw1995 posted 09-21-2007 11:41 PM 1831 views 1 time favorited 4 replies Add to Favorites Watch
View jpw1995's profile
376 posts in 4229 days
09-21-2007 11:41 PM
Topic tags/keywords: resaw bandsaw
I thought I remembered seeing a discussion on this topic before, but I can’t seem to locate it. Does anyone know any good techniques for resawing without a bandsaw? I have a Rigid, but I don’t have a riser block. This, of course, means that I only have 6” of resaw capacity. I need to resaw and 9” wide board, and I need the full width so I can’t rip it down to 6” or less. Any ideas?
-- JP, Louisville, KY
View MattD's profile
150 posts in 3875 days
#1 posted 09-21-2007 11:50 PM
Use your bandsaw to make a frame saw
-- Matt - Syracuse, NY
View gizmodyne's profile
1771 posts in 4021 days
#2 posted 09-22-2007 03:36 AM
You can cut a groove down each edge with your table saw, gradualy raising the blade up to full height.. Then use a handsaw to cut through the middle of it. The groove helps to guide it
Just be careful and down think about standing the board up one its ends for a run through the saw. Plane both faces first and then you can just plane off the weird middle piece later.
-- -John "Do I have to keep typing a smiley? Just assume it's a joke."
View jstewart's profile
141 posts in 4022 days
#3 posted 09-22-2007 04:23 AM
Gizmodyne has a good idea there, but I think you can get even more with the table saw. You could stand the board up on end and run it through if you have a tenoning jig. The frame saw is my favorite idea so far. Get back to what people had to do before electricity. You’ll give your arms a great workout.
You could also try to get some time in the shop of a local highschool. The one by my house won’t let me use the tools (for liability reasons) but they did say they could have their students do some work for me.
-- Joshua, Olathe, Kansas
View Woodminer's profile
69 posts in 3868 days
#4 posted 09-22-2007 05:26 AM
Or if you have a store that sells wood, they’ll often do a single cut for you on their 12 or 14” bandsaw for a buck or three. Cheaper by far than affording your own large enough bandsaw.
You usually have to have a relationship with them to do this, but that ain’t hard. Just hang around and buy the occasional bit of stuff. Handy to have that kind of friend.
I have used Gizmodyne’s method, though, resawing a couple pieces of mahogany that I bought on eBay…
-- Dean, Missouri
