Square slot question
Forum topic by ndhwoodworker posted 06-22-2015 09:17 AM 1124 views 0 times favorited 16 replies Add to Favorites Watch
View ndhwoodworker's profile
ndhwoodworker
2 posts in 1246 days
06-22-2015 09:17 AM
Topic tags/keywords: slots log knife block problem elm stuck
ok so I’m making a knife block out of a solid log. i don’t want to cut the log and use a router to make the knife slots like a normal knife block, so i was wondering if there was a way to make the slots for the knives without cutting the log into pieces and gluing it back together. i want to keep the log one solid piece so that it adds character and also I’m afraid that the bark or outer part might be messed up if i cut it all up…? any tips??
16 replies so far
View michelletwo's profile
michelletwo
2761 posts in 3190 days
#1 posted 06-22-2015 11:34 AM
drilling & chisels? mortiser?
View Woodknack's profile
Woodknack
12399 posts in 2554 days
#2 posted 06-22-2015 11:17 PM
chain mortiser
View timbertailor's profile
timbertailor
1594 posts in 1598 days
#3 posted 06-22-2015 11:26 PM
ndhwoodworker
#4 posted 06-22-2015 11:31 PM
@michelletwo and @rickm a Mortiser is too expensive for just this project
View TheFridge's profile
TheFridge
10500 posts in 1660 days
#5 posted 06-22-2015 11:34 PM
1/8” mortising chisel?
View waho6o9's profile (online now)
waho6o9
8481 posts in 2751 days
#6 posted 06-23-2015 12:21 AM
Mortise chisel
Plunge router
& every ones’ favorite The Domino XL
View altendky's profile
altendky
169 posts in 2384 days
#7 posted 06-23-2015 12:50 AM
Are any of these suggestions good for anywhere near an 1/8” x 2” slot that is 12” deep? Maybe, I’m not the experienced one here, but it doesn’t sound like it.
View jerryminer's profile
jerryminer
944 posts in 1615 days
#8 posted 06-23-2015 01:01 AM
I don’t think there is a real practical way. Would even be tough with a 1/8” mortising chisel—-all endgrain cuts.
You COULD get set up for welding bandsaw blades, then drill a 1/8” hole, cut a 1/8” bandsaw blade, thread it through the hole, weld it, install on the saw, then cut your slot. Repeat for every slot. Not very practical, but possible.
The only really practical approach I see is cutting the log apart, cutting the slots, then re-gluing. Pracice on a scrap and see if you can make an invisible glue joint.
View barada83's profile
barada83
88 posts in 1360 days
#9 posted 06-23-2015 01:12 AM
Like Jerryminer said. Cut it apart and reglue. There is really no way I can think of that will make a decent result for your goal of a knife block besides magic, or perhaps lasers.
-- Mike
altendky
#10 posted 06-23-2015 01:25 AM
Depending on the bark perhaps you could avoid the kerf by splitting rather than cutting? It would almost certainly be more work to route a straight slot but with care and some cheating on the back/in side where it won’t be seen you might be able to pull something off. Also, depending on how well adhered the bark is you may be able to remove it, slice away, then replace the bark?
View crank49's profile
crank49
4032 posts in 3145 days
#11 posted 06-23-2015 02:53 AM
Just slice into the log only from the back side, to the depth of the slots; say 3”.
Then glue in some 1/8×1” strips to close the kerfs back up and leave 1/8×2” slots.
May have to remove the bark carefully as a sheet before cutting the kerfs, then glue it back.
Woodknack
#12 posted 06-23-2015 05:40 AM
Practically the best way is cut it apart. A chain mortiser would work if one existed that was sized for a kitchen knife but they are used on timber framing. The only other option I can think of is burning the slot by heating a piece of steel to red hot and pushing it into the wood—keep a bucket of water handy, you’ll need it.
View oldnovice's profile
oldnovice
7272 posts in 3542 days
#13 posted 06-23-2015 05:51 AM
Thereally are two way I can imagine doing this:
  1. use some long drill bit and drill a sequence of holes, then file, file, and file
  2. hollow out the back/bottom side (using Forstner bits) to a depth so you can cut slots with a router bit. then refill tell area you removed!
Caveat This was only a suggestion as I have never done/used either of the methods for making a knife block!
I have to go with cut it, slot it, glue it back together. To hide the slices used to make the slots, celebrate them by cutting a V groove or similar along the slice over the top and down the other side?
View MrRon's profile
MrRon
5137 posts in 3417 days
#14 posted 06-23-2015 06:24 PM
Since the problem is making a thin mortise, make the mortise bigger and make an insert of contrasting wood; mortise the log for the insert; drill and clean out waste Total depth to suit length of knife blades. This is just a general idea.
View SirIrb's profile
SirIrb
1239 posts in 1405 days
#15 posted 06-23-2015 07:07 PM
VERY VERY SMART AND TRAINED TERMITES.
I dont see a way to achieve this. The depth here will kill you. Im thinking on it but I am not feeling this one.
