Stacking dry lumber
Forum topic by The_Beast posted 06-22-2015 09:15 AM 1044 views 0 times favorited 12 replies Add to Favorites Watch
View The_Beast's profile
The_Beast
3 posts in 1064 days
06-22-2015 09:15 AM
Topic tags/keywords: wood lumber storage barn sticker slat kiln air
So I have a small amount (40ish, 4-10” wide, 8’ long, 4/4, maple/cherry, kiln/air dried but all dry to sub 13%) of wood that I need to store. I just graduated college (going to be a tech. edu/woods teacher) and am storing it in a barn. I used some 3” x 3” boards to get it off the damp wood barn floor and used slats (1/4” ~ 3/8” thick, 1 1/2” wide, random length) to separate the lumber. I also stacked some shorter boards on top of theses, using the same sticker method. I covered it with a tarp and called it a day.
I used 3 sets of slats to along the length of the stack, so they are more than 18” between slats/stickers. I also had to use 2 stickers side by side since none were long enough to cover the width of the stack.
So, I was wondering if this was good for 2-4 years of storage or should I use thicker/narrower (1” x 1” seems to be recommended) stickers, make sure they cover the width of the wood stack with a single sticker and make sure they are 18” between stickers? If not, is this good enough until I can deal with this (in about a month)?
Thanks for the help!
12 replies so far
View JeffP's profile
JeffP
573 posts in 1385 days
#1 posted 06-22-2015 11:11 AM
...storing it in a barn…the damp wood barn floor…covered it with a tarp
I’m no expert, but this sounds like a decent humidifier to add water to some dry wood.
When you have a chance, I would recommend putting down some plastic on the floor before re-stacking it. Otherwise, all that moisture from the floor is going to be rising up into your stack. The tarp serves only to hold that moisture in.
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
View michelletwo's profile
michelletwo
2735 posts in 3009 days
#2 posted 06-22-2015 11:28 AM
I concur with Jeff
View rwe2156's profile
rwe2156
2916 posts in 1474 days
#3 posted 06-22-2015 11:38 AM
If the floor is damp (why is it damp?) then yes, you need a moisture barrier.
Definitely use the larger stickers you’re not getting enough air flow with what you have.
Leave a good 1” gap between boards.
Never cover with a wood stack with a tarp because it restricts air flow, which is what you want.
As long as the wood is not exposed to direct moisture, you should be ok but if the wood might be exposed cover with some pieces of metal roofing or plywood.
Good luck on your future endeavors!
View Yonak's profile
Yonak
986 posts in 1514 days
#4 posted 06-22-2015 06:23 PM
The wood is dry, right ? ..Then my opinion is that you don’t need to sticker it. You should be able to dead stack it. Indeed, leaving gaps between the boards will allow an express avenue for moisture to travel to the boards. I would stack it level and tight and wrap it in plastic.
A dehumidifier couldn’t hurt, especially if you can confine the space somehow..
View Richard H's profile
Richard H
489 posts in 1674 days
#5 posted 06-22-2015 06:46 PM
If was going to store dried lumber in a unconditioned location for that long I would wax the end grain so it doesn’t split but that’s me. Other than that keep it out of the dirt and away from direct exposure to moister and insects.
View WDHLT15's profile
WDHLT15
1738 posts in 2469 days
#6 posted 06-23-2015 01:00 AM
Yonak is dead on. You do not need stickers. Flat stacking it will retard the movement of moisture back into the lumber from the surrounding environment.
View barada83's profile
barada83
86 posts in 1179 days
#7 posted 06-23-2015 01:16 AM
I don’t think you really need to worry about it too much. You are in a humid environment and going to pick up the moisture whether you like it or not. Unless you can get it into a Ziploc air tight bag you are going to get moisture. My solution- don’t fret the long term storage but be diligent with the short term. When you do bring it inside, let it sit a while before you touch it for milling. Like weeks or months if you can.
-- Mike
The_Beast
#8 posted 06-23-2015 02:53 AM
The barn floor was damp because it had rained the night before and I have to keep it cover to keep the bird crap off of it.
I’m getting a lot of different responses, I’m quite surprised
WDHLT15
#9 posted 06-23-2015 11:34 AM
Dead stacked, there is no air flow to carry higher humidity through the stack, so the wood will not gain moisture very fast at all if there are no stickers. Since the wood is already dry, you do not need stickers, and with the increased air flow over the layers with the stickers, your wood will pick up moisture from the air much much faster.
rwe2156
#10 posted 06-23-2015 01:23 PM
Ooops missed that about dry lumber (wow its only in the title dummy!)
Yeah, just stack it up like some others said.
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1169 days
#11 posted 06-23-2015 02:02 PM
I would consider raising it higher off the floor. Both for moisture but also to discourage bugs.
The_Beast
#12 posted 06-25-2015 11:10 PM
- rwe2156
Sounds like this is the concensus so I’ll restack when I’m back home.
Thanks guys!
