Making Hardwood Flooring
Forum topic by Mark posted 09-22-2009 04:12 PM 2402 views 0 times favorited 4 replies Add to Favorites Watch
View Mark's profile
Mark
1807 posts in 3143 days
09-22-2009 04:12 PM
Topic tags/keywords: question milling finishing
Alright LJ’s I want your input on something I’ve been thinking of for a while now and that would be making a custom hardwood floor. Have any of you ever made your own flooring? If so give me some info on your ways or just some ideas on how to. Thanks
-- M.K.
View GMman's profile
GMman
3902 posts in 3567 days
#1 posted 09-22-2009 04:15 PM
Todd A. Clippinger
8901 posts in 3969 days
#2 posted 09-22-2009 04:39 PM
The remodeling contractor in me says to buy it already manufactured.
If I had some trees and wanted to turn them into hardwood flooring, I would take the material to a mill shop and have them run it. I have laid floors and I know how many lineal feet you of strips it takes to do a room.
You would be milling the top flat, relief grooves in the bottom, the tongue, and the groove. Depending on how you mill the tongue, it might take two passes. Just to thickness the material it would take several passes in the planer.
You would be doing this for hundreds of pieces.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3156 days
#3 posted 09-23-2009 04:54 PM
We made the flooring for my store with oak from my door shop. If I hadn’t already had the Oak, I would totally agree with Todd—-Buy manufactured flooring. having a commercial shop made it easier, but not having the right equipment made it more difficult than I would like. It was ripped on a table saw wirh a power feed, then run on a big shaper, also with a power feed. The shaper cutter set is rather expensive—I would hate to run that much through a router table. We didn’t run the ends because it wasn’t practical on the shaper. Obviously it can be done, depending on your equipment—-the question is—Is it practical for you?
See the floor here http://lumberjocks.com/projects/19095
-- http://shepherdtoolandsupply.com/
View boonelumber's profile
boonelumber
11 posts in 2471 days
#4 posted 08-09-2011 08:56 AM
Hardwood is one of the best flooring options for homes. They offer a number of advantages that allow you to maximize on your investments. There is even so little maintenance required with this type of flooring. Learn more about hardwood flooring here http://www.phsservices.com
