Baldor 3/4 hp single phase motor
Forum topic by FancyShoes posted 06-21-2015 05:43 PM 675 views 0 times favorited 6 replies Add to Favorites Watch
View FancyShoes's profile
FancyShoes
550 posts in 1270 days
06-21-2015 05:43 PM
So i picked up this realy nice baldor motor! 3/4 hp single phase, figured it is definelty worth the $17.50 i bid on it! It ran great, incredibly it came with a free drill press!
I really wanted just the motor incase i need to swap out a 3 phase at some point. But having a drill press will be decent, it is a champion brand. However the whole thing wobbles when the motor is running.
View lndfilwiz's profile
lndfilwiz
101 posts in 1507 days
#1 posted 06-21-2015 05:49 PM
Where is it wobbling? The arbor or the motor itself?
-- Smile, it makes people wander what you are up to.
FancyShoes
#2 posted 06-21-2015 06:39 PM
The motor itself.
View HerbC's profile
HerbC
1721 posts in 2765 days
#3 posted 06-21-2015 06:56 PM
Remove belt.
Run drill press motor. If it still vibrates, remove pulley from motor, run motor by it self.
If motor does not vibrate w/o pulley, get new pulley.
If motor does not vibrate with pulley, get new belt (think about a link belt, might be worth the cost).
If unit vibrates when new belt is installed, check quill pulley and bearings.
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
FancyShoes
#4 posted 06-21-2015 06:59 PM
I will be uploading a video of it running. Its not a bad wobble, or vibration, just a slight one from the motion. You cant even tell from the video.
FancyShoes
#5 posted 06-21-2015 07:05 PM
View gfadvm's profile
gfadvm
14940 posts in 2596 days
#6 posted 06-21-2015 11:53 PM
I have that exact same motor on my ancient drillpress! And it is a beast.
HerbC’s advise for diagnosis and treatment is spot on!
Edit: watched the vid and vibration didn’t seem bad from here. Maybe a bag of sand or other weight on the base. Also shims under the base if the floor isn’t perfectly level.
