Repairing plastic handwheels
Forum topic by Octavius posted 66 days ago 337 views 0 times favorited 19 replies Add to Favorites Watch
View Octavius's profile
Octavius
20 posts in 71 days
66 days ago
Hi folks,
Moving forward with the renovation of the Craftsman table saw.
http://lumberjocks.com/topics/10325
Is it possible to repair those cracks?
I’m thinking of SuperGluing and then fitting to the shaft and drilling a hole through the knob and shaft and inserting a screw.
Cheers
View lew's profile
lew
4500 posts in 653 days
66 days ago
I don’t think super glue will be strong enough.
Depending on the type of plastic, there may be a glue that will act a solvent and “melt” the pieces together. I used to make underwater camera cases and the Plexiglas was glued together with this type of glue.
Another possibility MAY be to take it to an auto body shop. Some shops have a plastic “welding” machine to repair the newer car body parts. They might be able to help.
25806 posts in 1298 days
66 days ago
Epoxy might be better than super glue. The plastic welding machines use heated air to melt the plastic and then use a plastic rod to fill in any gaps. It might work, I don’t know the strength of plastic welding.
View GMman 's profile
GMman
1370 posts in 595 days
66 days ago
Get yourself some Loctite super glue and I am sure it will hold.
You have to clean it good ,I glued steel with it.
-- --<<<<<< I will not stop until I get it right. >>>>>>--
View bentlyj's profile
bentlyj
790 posts in 367 days
66 days ago
It might look ugly but maybe a hose clamp around it also.
View mmax's profile
mmax
52 posts in 353 days
66 days ago
Get some J-B Weld two part expoxy. The stuff is amazing.
-- Always remember you're unique, just like everyone else
View fredf's profile
fredf
320 posts in 607 days
66 days ago
a ring of tubing that will press over the hub would be a good reinforcement. rought up hub, coat with epoxy (and in cracks) and press ring on; fill around the bevel.
-- Fred, Springfield, Ma
GMman
66 days ago
I know you guys all like Epoxy I did too until I discovered Loctite super glue.
That stuff will weld anything.
GMman
66 days ago
Something like Fred said too with the glue press a bushing over for more strength.
View DaneJ's profile
DaneJ
54 posts in 106 days
66 days ago
go with the sleeve(tubing) and epoxy
Many times the hex has a taper to it so that it can be released from the mold… this kind of cracking(peak of hex) may be caused by overtightening the the bolt that holds it on the shaft.
-- Dane, Fairview Pk, OH. The large print giveth and the small print taketh away...
View Dan Lyke's profile
Dan Lyke
607 posts in 1022 days
66 days ago
I’d check out a chloroform based solvent to weld it, see if it’ll melt with that plastic. Otherwise, make a replacement out of a good void-free plywood…
I doubt epoxy will hold that plastic for very long, if you can’t find a solvent that’ll weld it cyanoacrylate (ie: “super glue”) might work, but I think that’d just be a temporary fix.
Octavius
20 posts in 71 days
66 days ago
Wow!
Thanks for all the replies!
Let me ponder and I’ll show you what I come up with.
Cheers
GMman
66 days ago
Anyone who thinks that epoxy will work I say no way epoxy for me is a waste of time.
Go with loctite super glue it is 100% better than epoxy.
3050 posts in 919 days
66 days ago
I’d try to buy a new one and keep the repaired one for a spare.
View WibblyPig's profile
WibblyPig
84 posts in 172 days
66 days ago
Try Grainger and get a metal one – probably 15-30 bucks.
-- Steve, Webster Groves, MO
View SCOTSMAN's profile
SCOTSMAN
2244 posts in 483 days
66 days ago
Yes my 3 cents bin it and buy new it will never be the same again they are made cheap and disposable for a few dollars get a new one that’s what BIG AL would do and I know him like I know myself.Alistair
Octavius
20 posts in 71 days
64 days ago
Thanks again for the comments and suggestions – all duly noted.
I had a message asking how it has turned out.
Well, I’m still kind of working on it. I’ve used Loctite Super Glue in the actual cracks and then used a hose clamp (as suggested by bentlyj) to close up the gap while the glue dried. The plan is next to find some kind of bushing and epoxy it in (I have some JB Weld someplace).
Actually, it just might hold up with the superglue – I believe I have fixed the cause of the stiffness that caused the previous owner to crack the handles in the first place. If none of this works in the long run, I’ll just buy some news wheel handles, as suggested.
In other news, I’ve now totally re-assembled the saw and tried it at cross cutting a piece of pine – seems to work just fine. Quite pleased with myself. Plus the saw is not super loud (being belt driven). Still got some more stuff to do on it. It came w/o a blade guard and the very least I think a splitter would be in order. Trouble is all these extras add up – I’d like a new saw blade (instead of borrowing one from my miter saw), a zero-whatsit throat plate, that fancy splitter that fits in the throat plate, machined pulleys and that special belt and maybe that PALS setup.
Oh yeah, you’re going to hate me. I was fussing with that saw blade/ miter channel alignment – you know, tapping the trunnions, and all that. Using a dial indicator I got it to where I thought was good enough and then I tightened down all six trunnion bolts. When re-checked with the dial indicator, it was dead nuts on!! Front of blade showed 86.5 thou, rotated blade back and got 86.5!
Cheers for now.
DaneJ
63 days ago
hey I had another thought… if the hub is the right size you may be able to use a female pipe coupling… pipe thread is tapered and may tighten up everything, epoxy or loctite would lock it in.
Octavius
20 posts in 71 days
62 days ago
Dane,
Sounds good! Let me check out Home Depot and see what they have got.
Dick, & Barb Cain
7043 posts in 1197 days
62 days ago
You can also do like I diid with the blade guides on my old bandsaw. They were aluminum and cracked when tightening the set screw. I wrapped them with fine wire, then epoxied over it.
Check the picture it lasted many years.
