| Forum topic by midgefridge25 | posted 69 days ago | 302 views | 0 times favorited | 5 replies | ![]() |
69 days ago |
69 days ago |
More details would probably be helpful. Are these round mortises/tenons? Rectangular? Do the logs have a flat face on which to register a drill press attachment, for example? Or are you going totally rustic here? If rustic is the answer, then a round tenon cutter on a good drill combined with an auger bit to cut the mortises is probably your best bet. -- Anything worth doing is worth redoing several times. |
69 days ago |
You can cut mortises in many different ways. A drill bit in a drill press would work. It would Another way is to use a router. A plunge router with a fence works well. You could also Tom |
69 days ago |
I’ve cut mortises with a hand held drill and drill bit successfully. A doweling jig costs under $50, and you can use it for other joinery. -- Gerry |
65 days ago |
Gerry you are right. People some time use a brace to drill the holes too. I guess it just Does the doweling jig just center the holes or does it help keep the holes straight? Tom |
65 days ago |
http://i615.photobucket.com/albums/tt240/lcurrent/th_IMG_0118.jpg http://i615.photobucket.com/albums/tt240/lcurrent/th_P1010008.jpg http://i615.photobucket.com/albums/tt240/lcurrent/th_IMG_0013.jpg http://i615.photobucket.com/albums/tt240/lcurrent/th_P1010008.jpg Last photo LCJIG much much easier Larry -- lcurrent ( It's not a mistake till you run out of wood ) |
| Forum | Topics |
Woodworking Skill Share
2937 |
3968 |
260 |
956 |
226 |
Woodworking Trade & Swap
624 |
Coffee Lounge
2403 |
LumberJocks.com Site Feedback
525 |
