A handplane I can't find on the Internet
« back to Hand Tools forum
Forum topic by emiliof posted 06-20-2015 02:36 PM 1216 views 0 times favorited 7 replies Add to Favorites Watch
View emiliof's profile
emiliof
33 posts in 1863 days
06-20-2015 02:36 PM
Topic tags/keywords: vintage handplane alumimium stahls
I bought a presumably old handplane. The seller could not explain its origin, only that it belonged to his father. I have been looking for this plane or similar ones on the internet but I haven’t found anything.
I bought it without the iron. The lever cap was sort of sharpened, which looks to me like a desperate attempt to make it work without the iron, because the lever cap is long enough for protruding from the mouth. I guess the lever cap is that long because it also plays the role of the chip breaker. I may well be wrong.
The brand on the lever cap is Stahls, apparently swedish, but I can not tell it for sure after a long searching session on google.
It’s about the size of a #3 Stanley plane but the iron is 1 5/8” wide instead of 1 3/4”. I fitted an iron from an old block plane and it works well. Its body is made of aluminium.
It does not have a frog like the stanley bailey planes but a sort of ramp where the iron rests. The ramp is part of the body and it has a minimalistic structure in terms of volume. This design, combined with the fact that the plane has an aluminium body, renders a very lightweight tool. I guess the absence of the chip breaker could have been a decision for making it very lightweight. Including the iron I fitted to it, this handplane weighs 600 grams, that is 1-1/3 pounds, having a 9-1/8 inches long sole.
Judging by visible consequences on the heel, I also guess the technique for tuning the cut depth includes tapping the heel with a hammer, like you do for wooden planes.
Are my guesses right? Could anyone tell a bit more about this plane? Should I improve my googling techniques? :-)
Cheers!
Emilio
-- Emilio
7 replies so far
View poopiekat's profile
poopiekat
4322 posts in 3604 days
#1 posted 06-20-2015 05:05 PM
The only “Stahl” plane I’ve ever seen is a #78, an exact knockoff of a Stanley #78. It’s frequently listed in eBay, and never gets any bids. There’s some great Swedish planes out there, notably Memo, and Esteel, , but this in my opinion is not up there, quality-wise. The aluminum body is interesting, though!
View bandit571's profile
bandit571
18881 posts in 2553 days
#2 posted 06-20-2015 05:59 PM
Just saw a Stahls spokeshave on the FeeBay…...couldn’t find any planes, though. It appears as though Stahls has moved on to other types of tools, though. mainly things like soldering guns, and electronics hand tools…
View rwe2156's profile
rwe2156
2747 posts in 1350 days
#3 posted 06-20-2015 09:05 PM
You should have passed on this one unless you wanted it just for the novelty of it.
1) How can a frog with basically no bearing surface possible work very well?
2) How could aluminum be a good choice? Its so subject to warping it probably flexes just clamping the blade.
3) What can be good about 1 1/3# pounds in a bench plane?
bandit571
#4 posted 06-20-2015 09:23 PM
Ok, here it goes again..
For one thing, it would make a decent enough scrub plane
1) Ask THAT of any Stanley No. 110. About half of all block planes use this style of “frog”
2) Might ask Stanley, as they made a full range of bench plane that used aluminum for their bases. Ever try to buy a No. A6? IF you can even find one, they will be expensive to own.
3) What exactly does how much a plane weigh mean to how it would work?? I’m at a loss to figure #3 out. Run out of reasons?
It might even work as a handled block plane. Or, just add a camber of 8-9” radius to the edge, and scrub away. Once the depth is set, no reason to fiddle any longer with it, just use it.
View johnstoneb's profile
johnstoneb
2690 posts in 2042 days
#5 posted 06-20-2015 09:29 PM
I wasn’t aware that aluminum was subject to warping. As long as the mouth supports the iron fully the rest of the frog just supports the angle of the iron.
-- Bruce, Boise, ID
View Don W's profile
Don W
18554 posts in 2437 days
#6 posted 06-20-2015 11:03 PM
Interesting design.
emiliof
#7 posted 06-21-2015 01:29 PM
Thank you all for your answers and opinions!!!
Yes, I personally prefer heavy planes, I feel particularly comfortable using a 4 1/2 plane.
However, you find a myriad of Stanley plane models, not to mention other brands. Most of them were designed for a very specific purpose.
I wonder what could have been the specific purpose that the designer of this extremely lightweight plane (for its size) had in mind. Probably planing a wooden ceiling :-)
I bought it within a lot of old tools, that included a very nice Lufkin combination square (20cm or 8 inches), with a “drop forged and hardened head” and a vintage Stanley bevel square… It was a bargain, really.
Cheers!
-- Emilio
