Help identify this MF brace
« back to Hand Tools forum
Forum topic by BinghamtonEd posted 06-19-2015 01:18 PM 957 views 0 times favorited 9 replies Add to Favorites Watch
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2365 days
06-19-2015 01:18 PM
So I was doing the neighborhood yard sale with my daughter last weekend, and I picked up a nice Stanley brace for $1. Score. Then the guy asked me if I wanted this for $1, and I said sure. The chances that I will ever use this are slim to none, but I figure if nothing else, it’s a nice wall decoration for the shop.
The chuck says Millers Falls on it, but that’s all I can make out. I haven’t cleaned it up at all yet. I don’t even know what this would be used for. It has the handle out at an angle like a joist drill, but it has a plate for bracing against it on one end. I don’t know if this is a chest brace, or maybe you could put your knee against it for drilling holes down low? I also don’t know if this is an original item, or if it’s a modification of one.
- It appears to be missing a piece, if you look on the bottom side, above the chuck, there is a hole that looks like something should be in there.
- Up near the top, the wing-nut style sleeve on the end loosens and tightens, allowing you to slide the bracing pad (or whatever its called) to change the angle of the pad to the rod it mounts on.
- The thumbscrew on the handle allows you to change the sweep of the handle by sliding the rod towards or away the drive shaft.
- The angle of the drive shaft (sorry, don’t know the correct term) to the chuck is non-adjustable. I’ve seen other braces that have some adjustability, but this appears to be fixed.
So, can anybody figure this one out?
9 replies so far
View chrisstef's profile (online now)
chrisstef
17380 posts in 3001 days
#1 posted 06-19-2015 01:59 PM
Ive never seen nothing like it. Does it turn the chuck? Could it be missing the gears? A quick search on old tool heaven’s MF page doesn’t turn up anything. Im intrigued.
The only thing that looks close is the No. 666.
View mahdee's profile
mahdee
3883 posts in 1763 days
#2 posted 06-19-2015 03:29 PM
It looks like what they called corner brace. I have seen a 502 model but not this one.
here is a link to images:
They sell for about $15-$25
-- earthartandfoods.com
View rwe2156's profile
rwe2156
2923 posts in 1476 days
#3 posted 06-19-2015 04:21 PM
Corner brace or knee brace.
I noticed the adjustable handle.
Cool tool.
BinghamtonEd
#4 posted 06-19-2015 04:44 PM
I might have to do a little cleanup on this to see if I can find any markings, so far I have not. I see the corner braces, but I can’t find any that have the handle off to the side and the chest/knee brace on them. I’m thinking that the piece that is missing is probably a stationary handle to hold with your other hand.
mahdee
#5 posted 06-20-2015 03:03 AM
Yea, something is missing there for sure.
View Bluepine38's profile
Bluepine38
3379 posts in 3080 days
#6 posted 06-20-2015 03:52 PM
Definitely different, now that you have us curious, please let us know what you find out.
BinghamtonEd
#7 posted 06-22-2015 01:32 AM
Update : I’ve done some more searching and identified the brace. It was created my Stephen McClellan, who patented a couple braces and drills while working as a salesman for the MF company, and used their chucks. I think this is a pretty neat piece. I might post it over in the swap and see if anyone has a router or rabbet plane that needs some cleaning up for it, but otherwise it’ll probably just go on the wall.
http://www.nzvtcc.org.nz/ftools1.htm
View poopiekat's profile
poopiekat
4354 posts in 3729 days
#8 posted 06-22-2015 01:59 AM
Here’s my corner brace, Ed! Yours seems to be a much rarer, earlier version and yours incorporates a breastpiece to the corner brace design. Indeed, they were used for boring a hole in a floor, close to a wall where the swing of a normal bit brace made it impossible to get close enough. They certainly have value, but I hesitate to wear out my good bits so I rarely reach for a brace of any kind.
Bluepine38
#9 posted 06-22-2015 03:26 PM
Thanks for the update Ed. Nice to see that you had to use a New Zealand scource to find out about an
old USA drill. As the tool man would say, “We just have to put a bigger motor on it.”
