Need help finding a replacement belt for my Carba-Tec mini-lathe
Forum topic by Ken Waller posted 69 days ago 278 views 0 times favorited 7 replies Add to Favorites Watch
View Ken Waller's profile
Ken Waller
44 posts in 69 days
69 days ago
Topic tags/keywords: v-belt drive belt mini-lathe
I have a 20+ year old Carba-Tec whose belt is not long for this world. The belt is 3/16” by 25” total length. Does anyone know where I can get a replacement. Current Carba-Tecs have smaller belts and belt suppliers I’ve checked don’t have a belt that narrow.
Ken
-- Ken in Sharbot Lake, Ontario
Ken Waller
44 posts in 69 days
68 days ago
I found one!!!
I found a similar belt that was too short and found the manufacturers name on the belt. Went to www.gates.com and was able to find the belt and a local company who could order one for me.
For the benefit of those looking for belts in the future.
View jockmike2's profile
7356 posts in 1145 days
68 days ago
Have you ever tried those segmented red belts. They will sure take vibration out of any machine and you can get them to fit any machine because you can add and subtract links to your needs. Expensive though.
-- Mike. mwurm13@yahoo.com
Ken Waller
44 posts in 69 days
68 days ago
Hi Mike,
I have the segmented belts on my tablesaw and my General 260 lathe and they do work wonders in eliminating vibration. Unfortunately they are too wide to use on the Carba-Tec.
View Andrew's profile
Andrew
107 posts in 97 days
30 days ago
I had a craftsman lathe and the inner transmission belt would wear out every 2 months and Sears would fix it ( thank You super 5 year protection agreement) anyway I no longer have that problem. A freind of mine talked to his Gates rep and told him my problem showing him my old belts. Sears was installing Gates belts made in China, he sampled me 5 Kevlar versions of the belt, also At the same time Sears decided to replace the Lathe with a JET 16/42 So no more problem, For more detail you can read my ” MY new Favorite TOY” review on the lathe. Until Sears asks for the old lathe it lives in a freinds garage. Anyway check to see what version of the Gates belt you acquired. I might be able to put you in contact with the rep if you need it.
Happy rotating.
-- As the Saw Turns
25811 posts in 1299 days
30 days ago
Thanks for the tip on belts.
View Chris Wright's profile
Chris Wright
360 posts in 380 days
30 days ago
Since you’ve found a replacement belt already I guess it’s not as big of a deal, but later down the road, if you need to replace it again, you can look into replaceing the pulleys as well. That way you can get a different, more readily available belt.
-- "At its best, life is completely unpredictable." - Christopher Walken
Ken Waller
44 posts in 69 days
28 days ago
Thanks all for the help and suggestions. I just picked up the 2nd of the 2 belts I ordered (now I have a spare). At $28.00 a piece for such a small belt it was tempting to only buy the one. Having a spare should ‘guarantee’ I won’t need one for a while. Andrew, you may want to pass on to your friend to pass on to the Gates rep, that searching the web did not put me on to the Gates site (maybe if I’d checked out all of the 3 million hits I had for “machinery drive belts” I might have found it) As it was, I noticed the name on a too-small belt sent to me by a woodturning supplier. Otherwise I would still be looking.
