Some tool humor
Forum topic by thelt posted 09-20-2009 02:57 PM 1361 views 0 times favorited 8 replies Add to Favorites Watch
View thelt's profile
thelt
665 posts in 3577 days
09-20-2009 02:57 PM
I haven’t seen this on here anywhere, but it may be a repeat. Enjoy.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the
chest and flings your beer across the room, denting the
freshly-painted project which you had carefully set in the corner
where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprints
and hard-earned calluses from fingers in about the time it takes you
to say, ‘Oh sh—‘
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation
of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt
heads. If nothing else is available, they can also be used to transfer
intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various
flammable objects in your shop on fire. Also handy for igniting the
grease inside the wheel hub out of which you want to remove a bearing
race.
TABLE SAW: A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new brake shoes, trapping the jack
handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops
to cut good aluminum sheet into smaller pieces that more easily fit
into the trash can after you cut on the inside of the line instead of
the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength
of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under
lids or for opening old-style paper-and-tin oil cans and splashing oil
on your shirt; but can also be used, as the name implies, to strip out
Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used
to convert common slotted screws into non-removable screws and
butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays
is used as a kind of divining rod to locate the most expensive parts
adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly
well on contents such as seats, vinyl records, liquids in plastic
bottles, collector magazines, refund checks, and rubber or plastic
parts. Especially useful for slicing work clothes, but only while in
use.
DAMN-IT TOOL: Any handy tool that you grab and throw across the garage
while yelling ‘DAMM-IT’ at the top of your lungs. It is also, most
often, the next tool that you will need.
-- When asked what I did to make life worthwhile in my lifetime....I can respond with a great deal of pride and satisfaction, "I served a career in the United States Navy."
8 replies so far
View GMman's profile
GMman
3902 posts in 3895 days
#1 posted 09-20-2009 03:52 PM
All good but I like the last one the best!
View cabinetmaster's profile
cabinetmaster
10874 posts in 3756 days
#2 posted 09-20-2009 03:55 PM
ROFLMAO. I love this one. Great find.
View dreadhead's profile
dreadhead
28 posts in 3565 days
#3 posted 09-20-2009 08:49 PM
Thanks for the post :D it was a much needed laugh
-- - Marco
View Dusty56's profile
Dusty56
11822 posts in 3886 days
#4 posted 09-20-2009 09:43 PM
Thanks for the memories : )
View SnowyRiver's profile
SnowyRiver
51457 posts in 3678 days
#5 posted 09-20-2009 11:15 PM
Those are great !
-- Wayne - Plymouth MN
View huff's profile
huff
2828 posts in 3483 days
#6 posted 09-21-2009 04:34 AM
I’ve got everyone of those tools…......usually with the same results. Thanks for the laugh.
-- John @ http://www.thehuffordfurnituregroup.com
View Innovator's profile
Innovator
3584 posts in 3611 days
#7 posted 09-21-2009 04:55 AM
All too true.
-- Whether You Think You Can or You Think You Can't, YOU ARE RIGHT!!!
View woodsmithshop's profile (online now)
woodsmithshop
1346 posts in 3743 days
#8 posted 09-21-2009 05:01 AM
you’ve been looking in my shop window
-- Smitty!!!
