hand plane refurb - to pitted to fix?
« back to Hand Tools forum
Forum topic by smboudreaux posted 06-18-2015 11:13 PM 1662 views 0 times favorited 12 replies Add to Favorites Watch
View smboudreaux's profile
smboudreaux
51 posts in 2567 days
06-18-2015 11:13 PM
I recently jumped on the hand plane wagon. I purchased a few off ebay to refurbish and bring back to life. The above are pictures of a stanley #5, after about 2 hours of work on 80 grit paper. It’s still quite a ways out. Would you guys consider this one to far gone?
12 replies so far
View skeys's profile
skeys
14 posts in 1528 days
#1 posted 06-18-2015 11:32 PM
It looks like you’re almost there to me. I don’t think you need the entire sole to be perfect. I’d like it to be a bit smoother right in front of and behind the mouth, but other than that it looks like you’re good.
-- Scott K., Virginia https://www.etsy.com/shop/HaresEarDesigns
View bobasaurus's profile
bobasaurus
3451 posts in 3183 days
#2 posted 06-18-2015 11:47 PM
I agree with Scott. Get the area around the mouth a little bit smoother and it will work fine. Getting the sole perfectly unblemished is not necessary, if anything the pits will reduce friction in use.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View JayT's profile (online now)
JayT
5632 posts in 2210 days
#3 posted 06-18-2015 11:54 PM
+2 on the above.
How flat and smooth also depends on how you plan to use it. If you are going to use that one as a jack plane with a cambered iron for rough work, then how smooth isn’t all that critical.
View bandit571's profile
bandit571
20008 posts in 2683 days
#4 posted 06-18-2015 11:58 PM
What we have here is a Poor man’s “C” model plane.
Moved it across the wood, any drag to it? Does the sole rock any? No? put it back together, sharpenen the iron up, and put that jack plane back to work. Rub a Parafin candle all over the sole, to the point that the “pits” are filled up. And then put it to work.
smboudreaux
#5 posted 06-19-2015 12:10 AM
It doesn’t rock at all and I haven’t noticed any drag across the wood. The intended use will be as a jack plane. I was lucky enough to get a #4 smoothing plane in pretty good shape as far as I can tell. Thanks for the input fellas. I’ll finish her out and put her to work
smboudreaux
#6 posted 06-19-2015 12:11 AM
View sikrap's profile
sikrap
1121 posts in 3358 days
#7 posted 06-19-2015 01:23 AM
If it was a smoother or even a jointer, I’d say to keep going. Since you will be using it as a jack and that usually means coarse work, I’d say to sharpen the iron and see how well it works.
-- Dave, Colonie, NY
View Tim's profile
Tim
3807 posts in 1961 days
#8 posted 06-19-2015 01:28 AM
For rough jack plane work it’s probably good enough for the reasons Bandit said. For the record I find a large very coarse file will flatten the bottom of a hand plane much faster than 80 grit paper, but it takes a little bit of file skills to keep/get it flat.
View Holbs's profile
Holbs
1869 posts in 2029 days
#9 posted 06-19-2015 02:00 AM
I think it adds flavor :) A nice contrast! Straight lines and dimple holes.
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
View bondogaposis's profile
bondogaposis
4727 posts in 2351 days
#10 posted 06-19-2015 02:05 AM
For jack plane it doesn’t need to be perfect, it looks like it will work fine as it is now.
-- Bondo Gaposis
View TheFridge's profile
TheFridge
9471 posts in 1485 days
#11 posted 06-19-2015 02:14 AM
You should a #5 that I have. Worse than that. I use it for a scrub so I haven’t touched the bottom.
I’ll echo what they said.
View BurlyBob's profile
BurlyBob
5494 posts in 2265 days
#12 posted 06-19-2015 02:21 AM
Take what Tim said to heart. Get a good file and carefully secure it in a vise so the sole is just barely above the edges of the vise and start draw filing. I spent 6-8 hours on a Stanley #4 1/2 as the edges were much higher than the sole. Draw filing – Drawing the file from one end of the sole to the other, only in one direction. Don’t try to scrub the sole in both directions, you’ll wear the file out and accomplish little. I found that cleaning the file with a brush was helpful. Patience and time are the key. You can’t rush a good thing. A hand plane, well tune and sharp is a very good thing. It takes time and attention to detail to get there.
