safety glasses fog up
Forum topic by okwoodshop posted 09-20-2009 04:52 AM 4084 views 0 times favorited 15 replies Add to Favorites Watch
View okwoodshop's profile
okwoodshop
448 posts in 3137 days
09-20-2009 04:52 AM
Topic tags/keywords: question
my safety glasses always fog up when i am wearing a dust mask, this is really annoying and dangerous when sawing. i’ve tried different glasses but they all seem to do it, I use regular dust masks with the little metal strip on top. anyone else have this problem and how do you fix it.
15 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3675 days
#1 posted 09-20-2009 05:03 AM
I think the ‘seal’ from that little metal strip is next to useless and will always allow (and even direct) your exhaled breath inside your goggles. I think the real answer is to get one of those proper dust masks with the strap that goes around your head to provide a positive seal.
View 747DRVR's profile
747DRVR
199 posts in 3319 days
#2 posted 09-20-2009 05:04 AM
Masks with the little plastic exhaust on the front cut down on the fogging quite a bit but doesnt iliminate it completely.When I put the glasses on I can generally get about 2 or 3 cuts in before the glasses start to fog.
35111 posts in 4363 days
#3 posted 09-20-2009 05:42 AM
I use dust-be-gone and don’t have the problem.
117060 posts in 3539 days
#4 posted 09-20-2009 05:51 AM
Dust b gone
27250 posts in 3784 days
#5 posted 09-20-2009 01:35 PM
I have just gone to wearing my respirator. It has a tight fit and my glasses don’t fog.
View hootr's profile
hootr
183 posts in 3309 days
#6 posted 09-20-2009 02:21 PM
Rain-x makes anti fog product for windshields
I’ve had good luck with it on my welding helmet
-- Ron, Missouri
View Rev_John's profile
Rev_John
93 posts in 3851 days
#7 posted 09-20-2009 04:23 PM
i have used dryer softening sheets. The kind that you toss in the drier to soften and anti-cling.
-- John from Jackson, Michigan
View rowdy's profile
rowdy
375 posts in 3405 days
#8 posted 09-20-2009 04:30 PM
Another option is the Resp-o-rator. They are pretty comfortable, provide really good protection, and absolutely eliminate fogging.
-- Rowdy in Kechi, Kansas
View Vicki's profile
Vicki
1096 posts in 3307 days
#9 posted 09-20-2009 04:56 PM
Dust B Gone. Works like a charm. Just hand wash and let air dry when dusty.
-- Vicki on the Eastern Shore of MD
View FirehouseWoodworking's profile
705 posts in 3236 days
#10 posted 09-20-2009 10:13 PM
You can try a trick that many scuba divers use.
A drop of children’s tear-free shampoo (the yellow kind) on each side of each lense. Rub it around with your finger, then dip the glasses in a bowl of clean water (don’t rinse under the faucet, it will remove too much of the shampoo.) Let them air dry. You should be good for a couple days or weeks, depending on how much you use them.
Use a clean dryer sheet to clean off the dust.
Works great and is a relatively easy to find and inexpensive solution.
Cheers!
-- Dave; Lansing, Kansas
View Don Newton's profile
Don Newton
714 posts in 3581 days
#11 posted 09-20-2009 11:28 PM
Use the molded masks with the exhaust valve.
-- Don, Pittsburgh
okwoodshop
#12 posted 09-21-2009 12:04 AM
thanks for all the suggestions i am going to try them next week if possible. i have respirator i wear when spraying but it gets hot, maybe those dust masks with valve. the ones i have are useless they let a lot of dust in around the nose, cedar dust chokes me up!
View CyBorge's profile
CyBorge
79 posts in 3137 days
#13 posted 09-21-2009 06:35 AM
On those cheap paper masks, I have found that the fogging problem can sometimes be lessened by simply pinching the metal strip (while the mask is on) so that it bends a little tighter over your nose.
-- "How can I be lost if I've got nowhere to go?"
View EzJack's profile
EzJack
456 posts in 3133 days
#14 posted 09-21-2009 08:03 AM
I concur hootr, rain-x works on glasses also.
-- Ain't better or worse than any other woodpecker in the woods.
View ajosephg's profile
ajosephg
1880 posts in 3523 days
#15 posted 09-21-2009 03:34 PM
I like a face shield better than glasses. It protects a larger area, doesn’t fog, and you can wear regular glasses (in my case reading glasses) under it.
-- Joe
