Masking off wood before glueing and J-B Weld?
« back to Joinery forum
Forum topic by WoodNSawdust posted 06-18-2015 02:37 PM 786 views 0 times favorited 1 reply Add to Favorites Watch
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1263 days
06-18-2015 02:37 PM
Topic tags/keywords: painters tape masking before gluing j-b weld glue squeeze out
I normally use 3M blue painters tape to mask off areas that I don’t want glue squeeze out to get on. This method has worked well for Titebond woodworkers glue. The other day I did the same procedure and then used J-B Weld glue and found that the tape lifted up and J-B Weld got under it.
I was wondering if there is something in J-B Weld that dissolves the adhesive that holds the tape to the wood?
1 reply so far
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2456 days
#1 posted 06-18-2015 02:53 PM
I don’t know, but I’ve found the green tape to do a better job at sealing off edges.
