How do I pull/remove a DC impeller?
Forum topic by JasonWagner posted 68 days ago 304 views 0 times favorited 12 replies Add to Favorites Watch
View JasonWagner's profile
JasonWagner
91 posts in 76 days
68 days ago
Topic tags/keywords: question dust collector impeller
I am mounting the blower of my DC1100 on the wall and want to rotate the blower housing so the outlet will face 90 degrees from where it is now. Now the intake would be down and the outlet will be perpendicular to the wall I want to run the exhaust parallel to. Problem is, I can’t figure out how to pull the impeller from the motor arbor. (there are two screws back there I can’t get to) I know what pulley pullers look like and I don’t see where I would clamp it to pull the impeller off. It’s all smooth except for two holes that are in between some bolts on the impeller. These holes don’t seem like they’d offer any grip for pulling either. I saw Bill Pentz said he switched his DC1100 11” impeller to a 12” impeller used on the DC1200. Maybe there’s a tool I don’t know about?
Here’s a pic: http://www.newwoodworker.com/reviews/graphics/photos/tools/jetdc1100rvu/impeller200.jpg
View DaneJ's profile
DaneJ
53 posts in 105 days
68 days ago
if the 2 holes are threaded, use a steering wheel puller…
-- Dane, Fairview Pk, OH. The large print giveth and the small print taketh away...
JasonWagner
91 posts in 76 days
67 days ago
not threaded and not through-holes….
View ahock's profile
ahock
72 posts in 220 days
67 days ago
I’d tap the holes, pop in two bolts (maybe even eye bolts) and then pull it.
-- Finding satisfaction in creation
View northwoodsman's profile
northwoodsman
100 posts in 643 days
67 days ago
Just a crazy idea… but what is the purpose of those two holes? Are they perhaps an opening to get at 2 screws?
-- NorthWoodsMan
View RetiredCoastie's profile
RetiredCoastie
231 posts in 79 days
67 days ago
The impeller is on a keyed shaft. If you have a soft metal drift, close to the diameter of the motor shaft but not larger than. Aluminum or brass would be preferred. Remove the arbor bolt or nut and Spray the shaft with break free or WD40 let sit for a few minutes and then take the drift and put it on the shaft end and rap with a hammer and it should free the impeller up. Parts break down. http://www.retrevo.com/r/22997ag209/10/Assembly#q=Jet+DC-1100A
-- Eagles may soar, but weasels don't get sucked into jet engines! Mike D.
View GMman 's profile
GMman
1371 posts in 594 days
67 days ago
The end nut maybe right hand tread and the fan treaded left hand.
-- --<<<<<< I will not stop until I get it right. >>>>>>--
GMman
67 days ago
How is your impeller coming?
JasonWagner
91 posts in 76 days
67 days ago
What’s a metal drift? I’ll try something like that. Thanks RetiredCoastie.
I’m pretty sure it’s not threaded on because of that key he mentioned.
The holes are not through holes…no access to screws.
View ondablade's profile
ondablade
68 posts in 95 days
67 days ago
Be careful not to do more than lightly tap the shaft end, or you risk harming the motor bearings. The safest option is probably to pull from threaded holes close to the hub of the fan, while the puller centre bears on the end of the motor shaft. A DIY pullers – a bit of flat strip and three bolts – would be easy too.
A quick touch of carefully placed heat from a gas torch to the impeller (while doing all possible to stop the shaft heating) might loosen it up too, but carries the same risk of doing harm. e.g. cooking the seals/causing the grease to run out of the motor bearings.
With a pullers you can do almost as you like and not do harm…..
-- Late awakener....
RetiredCoastie
67 days ago
Jason, a drift is a piece of round stock usually made of soft metal or even wood in some cases, used for taping out bolts, roll pins…etc. used to transfer pressure or impact energy to an object without deforming the object you’re trying to remove.
In a lot of cases it is a convenient place to rest the skin of a finger or hand in order to smack said skin with a hammer thus manufacturing blood blisters!
JasonWagner
91 posts in 76 days
67 days ago
Thanks for all the help guys. I threaded one of the holes, soaked the joint in WD-40, tapped the arbor a few times, then used the arbor bolt as a fulcrum to pull up on the one threaded bolt I added. That was all it took. I’m glad I went back to try to do what I wanted instead of rigging it. I rotated the blower housing to a more usable angle for my situation.
RetiredCoastie
67 days ago
Excellent, glad you got it rotated. Let us know how it turns out.
