bandsaw madness
Forum topic by texassteelpapa posted 06-18-2015 01:35 PM 749 views 0 times favorited 5 replies Add to Favorites Watch
View texassteelpapa's profile
texassteelpapa
21 posts in 993 days
06-18-2015 01:35 PM
I have a Jet JSL-12BS driving me crazy. The blade after about 5 minutes starts chunking rubber at me. I have broke it down ,cleaned it up even fell asleep with the manual gripped in my hands. I’m fixing to chunk it into a lake nearby. I replaced the wheel tires also. Is it me or is this model possessed .
5 replies so far
View Bill White's profile
Bill White
4862 posts in 3869 days
#1 posted 06-18-2015 01:54 PM
There are too many variables to address without more info.
Alignment, blade itself, bearings frozen/worn loose, guides, motor attachments. Just a few possibilities.
Help us help you before ya go crazy.
Operators and technicians are standing by to provide high quality, low dollar info. :)
Bill
-- bill@magraphics.us
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1123 days
#2 posted 06-18-2015 02:05 PM
As Bill said, it could be any number of issues, it is unusual but not unheard of. My guesses are that the blade is too tight, the set is wrong on the teeth, the blade has a bad weld, the bearings wobble, the posts ar bent, the wheels have a flat memory in them and need to be replaced, the throat is too narrow, the case is warped. I mean I could do this all day.
-- Talent, brilliance, and humility are my virtues.
View gfadvm's profile
gfadvm
14940 posts in 2599 days
#3 posted 06-19-2015 12:16 AM
Where is the “rubber” coming from? Tires, drive belt, table insert?
texassteelpapa
#4 posted 06-19-2015 01:06 AM
Thanks for the advice ,I was extremely frustrated but was calmed down by some sleep.A cabinet maker told me to go to ITURRA.COM , some guy has advice on taming a band saw. Rubber is coming from the tires slipping off the rim,on top. They were brand new.
gfadvm
#5 posted 06-19-2015 02:09 AM
The tires are moving/slipping on the wheel? Options: replace with proper sized urethane tires OR glue the tires to the wheel with automotive GOOP brand adhesive. I’ve used the GOOP as a temporary fix to get me through a weekend and it has lasted for several years!
