installing hinges ???
Forum topic by DMR posted 70 days ago 389 views 0 times favorited 10 replies Add to Favorites Watch
View DMR's profile
DMR
16 posts in 542 days
70 days ago
How can I install hinges for cabinet doors without an extra set of hands ? The doors aren’t huge, but they’re just heavy enough to make them awkward to handle. So far everything I’ve tried has failed! Any helpful hints would be greatly appreciated!
Thanks
View tomakazi's profile
tomakazi
246 posts in 182 days
70 days ago
what kind of hinges? there are a lot of different ways for a lot of different hinges.
-- I'm not here for your amusement. You're here for mine - Johnny Rotten
View DMR's profile
DMR
70 days ago
They’re non mortise finial hinges. My plan thus far has been to attach the hinges to the door then mark the face frame stiles. I can’t hold the door in place long enough to accurately make a mark nevertheless screw the the hinge to the stile. Thought maybe someone had an idea for a jig that would act as an extra set of hands. On smaller cabinets I could lay them on their side or face, but that won’t work with this piece.
View mics_54's profile
mics_54
432 posts in 369 days
70 days ago
On overlay doors I clamp a 3/4” x 3/4” piece of wood about 16” long (longer as needed) flush with the bottom of the face frame lower rail with spring clamps. my bottom rails are always 1 1/2” so that would be for 3/4 overlay but you can change as needed.
-- Dan, Sterling Alaska, http://sullcon.homestead.com/ Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes!
View DMR's profile
DMR
69 days ago
I got it done using some hand screws to help hold the door in place while I marked out the hinge location on the frame.
thanks for your help!
Donna
View skeezics's profile
skeezics
199 posts in 618 days
69 days ago
make a story stick. drill the stick for your screw pattern. use the stick to locate and pre-drill the door and style. tack a spacer on the top of the stick the same thickness as your reveal and let it over hang the stick. but the stick to the top of the opening and drill then hang the stick on the door and drill. mark the holes so you drill the correct ones on the correct parts.
-- hey honey! watch this!
View John Gray's profile
John Gray
1755 posts in 784 days
69 days ago
skeezics above has the great idea I will use it in the future.
View niki's profile
niki
429 posts in 978 days
69 days ago
View DMR's profile
DMR
69 days ago
Wow! Thanks for the excellent tips. Love the story stick idea. I think I’ll give that a try next time
Niki that is basically what I ended up doing except that I used two hand screws. One like you have pictured and another one to help balance the door in the frame. Thanks again! Donna
View Rich99's profile
Rich99
48 posts in 71 days
52 days ago
i like the pictures… nice clamps, niki.
-- Far-North Wood-Works (a fantasy company)
View niki's profile
niki
52 days ago
Thank you Rich99
You can see the “A to Z” (how to) here
http://lumberjocks.com/topics/1334
Wow, almost 2 years ago….
Regards
niki
