buying a dovetail jig
Forum topic by burl posted 72 days ago 485 views 0 times favorited 19 replies Add to Favorites Watch
Rockler
View burl's profile
burl
16 posts in 79 days
72 days ago
Topic tags/keywords: jig router resource joining traditional
I tried the hand cut method and failed marvelously!! But I don’t have a lot of discretional money to spend.
Hopefully one of the LJs will have some input for me. Thanks, burl
-- burl, Indiana,
View LesB's profile
LesB
555 posts in 343 days
72 days ago
I think the best recommendation with limited resources would be a Porter Cable jig. There are a number of others out there just stay away from the really cheap ones like Harbor Freight or Crafstsman might sell. That being said if you expect to do a lot of dovetails and box joints the Leigh is the best. I swear by mine.
-- Les B, Oregon
View Mario's profile
Mario
882 posts in 951 days
72 days ago
I have seen the Porter cable jigs going cheap as they are trying to push the new omni jigs.
-- Hope Never fails
View burl's profile
burl
16 posts in 79 days
72 days ago
Thanks, guys,
Does anybody know about the prazi jig?
-- burl, Indiana,
View Joe Lyddon's profile
Joe Lyddon
487 posts in 952 days
72 days ago
You might take a look at what MLCS has…
John Nixon has a nice video that demos them too! Very simple!
(be sure to watch it!)
They are on Sale now… I got the 1/2” shank Small setup…
With the template and all of the bits, etc. I think it’s a very good buy!
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/dovetailjig.html
If you want Half-blind DT’s just glue a face over the Through DT’s…
3056 posts in 921 days
72 days ago
I have the Leigh jig and it’s very good for production runs.
The akeda dovetail jig is also one you may be interested in as well.
You should still teach yourself to cut a decent dovetail. That involves practice.
View DaveR's profile
DaveR
1529 posts in 620 days
72 days ago
If you really haven’t got a lot of money to spend on a jig, you could make your own. The inexpensive jigs are all of the comb type. I think you could make your own templates and even make customized ones for different projects. You could even make your template work with the nice slender HSS dovetail bits if you’d like rather than the chubby carbide bits.
You could also cut dovetails with your bandsaw or tablesaw if you want.
Just ideas.
-- Until you spread your wings, you'll have no idea how far you can walk.
Joe Lyddon
72 days ago
Yep, here is a procedure for using a band saw…
http://www.woodworkstuff.net/bsdtj.html
View burl's profile
burl
16 posts in 79 days
72 days ago
DaveR, Do you know where to get plans for a shop built jig?
-- burl, Indiana,
DaveR
72 days ago
There was an article a few years back. I think it was written by Jamie Buxton. He wrote about making his own dovetail templates. I’ll see if I can figure out a link to it.
DaveR
72 days ago
Here’s a link. I hope it helps.
View burl's profile
burl
16 posts in 79 days
72 days ago
Thanks, Joe This will give me something to work on for a couple days. Thanks to you all.
-- burl, Indiana,
View AaronK's profile
AaronK
409 posts in 364 days
72 days ago
check out my thread on this subject. Depends what you mean by lack of funds, but the PC 4212 appears to give the best bang for buck. Since then i’ve read on improvements to the HF jig that make it much more functional. they had to do with adding some sandpaper to the clamp faces so the cams dont allow slipping and using perfectly dimensioned stock, i.e. 0.750, 0.500” etc. pieces.
Joe Lyddon
72 days ago
Here’s another inexpensive way to get dovetails…
... very similar to the MLCS jig except you make the Template from a Master!
http://www.stots.com/product/dttm.htm
View DavidH's profile
DavidH
128 posts in 643 days
72 days ago
shopenotes issue 43 has an article on a shop built dovetail jig, i haven’t attempted it myself.
-- David - Houston, Texas.
View SnowyRiver's profile
SnowyRiver
3535 posts in 380 days
72 days ago
Dont discount looking on Ebay, and Craigs List to name a few. They often have good deals on tools and there is usually a lot of DT jigs on there.
-- Wayne - Plymouth MN
View VariHz's profile
VariHz
3 posts in 72 days
69 days ago
As is turns out I’m selling the estate of a relative who was in the process of building a co-op wood shop when he got ill. There are 2 “new in the box” dovetail jigs available. One is the Porter Cable 4212 http://www.cpoworkshop.com/dovetail_jigs/4212.html?ref=froogle4212 and the other is a Woodline Route-R-Joint with videos etc http://www.woodline.com/p-1825-route-r-joint-precision-dovetail-joinery-system.aspx
Either one for $150 including UPS surface continental US freight. Email me at gmiller@pqei.com if interested.
-- A bad day in the shop is better than a normal evening in front of the TV.
View Kent Shepherd's profile
Kent Shepherd
840 posts in 186 days
69 days ago
Porter Cable 4212 is a good value, if you want standard dovetails. I have it, and it works well. If you’re wanting something more versatile, be prepared to spend some big bucks. However, Prazi has one for around $100 that will do variable spacing. The down side is it’s not as fast or easy as the good ones , especially for mutiple pieces. It depends on what you are looking for in a jig, and how much you are willing to spend.
View commajockey's profile
commajockey
16 posts in 180 days
69 days ago
I’m a bit late to this thread, but for basic needs, I highly recommend the Keller dovetail jig. It’s as simple as they get but very well made. And much more affordable than the other jigs. The only drawback is that it won’t do half-blind dovetails and changing spacing and such takes some creativity. I used it to bang out probably 20 sets of drawer boxes in an afternoon and it was a piece of cake.
-- Anything worth doing is worth redoing several times.
View Rob Drown's profile
Rob Drown
324 posts in 733 days
69 days ago
I have the rockler jig ( http://www.rockler.com/product.cfm?page=17367&tagem=rv ) and it is good. Follow the directions, clamp carefully and mark your pieces. Did I mention about marking your pieces. The dust collection hood is a real nice addition as without it you have chips everywhere.
-- Sharp tools and thin whispy shavings make woodworking a joy.
