Question about Laminates
« back to Coffee Lounge forum
Forum topic by SgtSnafu posted 70 days ago 162 views 0 times favorited 3 replies Add to Favorites Watch
View SgtSnafu's profile
SgtSnafu
63 posts in 169 days
70 days ago
Topic tags/keywords: plastic laminate question jig tip
Hey there fellow LumberJockers,
I was unsure which forum to post this – so here I am in the Coffee Lounge…
I have ran across a deal for a bundle of plastic laminate (about 100ish sheets of roughly 18×40). Other than using to make smooth jigs and shop work surfaces, anyone have any interesting ideas for the use of plastic laminates?
I believe first off I will be plying up several sheets (to be 5/16 to 3/8” thick) and cutting a range of different sizes holes (small to large) to have a circle, or hole template to be used with my router. I imagine I should scuff or sand the top surfaces to be adhered, but any suggestions on the best glue to make my laminate ply? Should I alternate the ply directions (like plywood)? Once I make mine, I can sell or trade the unopened commercial made one I have… ;-)
Thank you in advance for your time, and your ideas/opinions/suggestions…
~ Scotty AKA SgtSnafu
-- ~ SgtSnafu - Central North Carolina
View PurpLev's profile
PurpLev
2763 posts in 546 days
70 days ago
as far as I know laminates/plastics dont have grains…so no grain direction – so no need to alternate them when laminating them together. on the same note- why laminate them to one another? you could just laminate 1 to each side of a plywood, which would give you a rigid panel with a smooth surface for jigs/tables/etc. without the hassle of laminating so many to get to a needed thickness.
View Derrek LeRouax's profile
Derrek LeRouax
127 posts in 192 days
70 days ago
Scotty,
I use my PLAM a lot for shop situations, but not in rpojects that I plan to give to people. Mine is found mostly on jigs, as drawer liners, as an erasable story stick, as a “glue drip catcher”, things like that.
-- Derrek L.
SgtSnafu
70 days ago
PurpLev,
My main reason for wanting to laminate them for the circle template to emulate the commercially made phenolic one I have, and so it would last a lifetime and more… You have a good point – I believe for jigs and such I will use Baltic Birch or MDF as a base material.
Derrek
A glue drip catcher – now that is a good idea, I like it.
Thank you both for your input..
