| Forum topic by thelt | posted 69 days ago | 294 views | 2 times favorited | 6 replies | ![]() |
69 days ago |
For some reason I cannot get a true flat side when I run a piece on the jointer. One end is thinner than the other and it’s not snipe. I have made a lot of ships fly and wasted a lot of wood trying to flatten one side of two oak pieces for glueing purposes. I would appreciate any help. -- There are three signs of old age. The first is loss of memory. I forgot the other two! |
69 days ago |
Make sure the infeed and outfeed tables are perfectly parallel. You can taper the cut without getting snipe. Hope that helps. -- Kent Shepherd * The goal is-----More Tools! |
69 days ago |
When was the last time you changed the knifes? -- T. Nelson |
69 days ago |
I don’t know if you saw this post or not but Tom Hintz does a good job of addressing this issue. I have found that I get tapering, especially when face jointing, when (1) my knives were set higher than the outfeed table and (2) my technique with feeding the board through the jointer. I usually got tapering when I put too much pressure on the infeed side of the board. One thing that helped my face jointing, and made it safer as well, was this push block:
With this block I am able to maintain pretty even pressure on the board as it passes the cutterhead and it is relatively easy to transfer the pressure to the outfeed side of the board without losing contact with the board. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
69 days ago |
Is is obvious that there is an alignment problem of ether your feed tables, Back angle guide or knives maybe all 3 to some degree. Chances are about 75% that your parallelism is out. The best thing to do is get the Manuel for your joiner and follow the manufactures instructions. I wasted a lot of time and wood listening to people that said do this or that. No offense to any one, but I found you just have open the books and get your hands dirty on this kind of thing the nice thing is your angles and cuts come out better when you tune any machine and your more likely to keep it that way and not let it degrade to the point that you have to do something about it. -- Sell it here> http://woodworkerslist.com |
68 days ago |
Worse comes to worse and you cannot fix, run one board face up, run the next board face down and so on. If the first is 92 degrees, it will match to an edge on the next that will be 88 degrees. works like a champ. I do it even though my jointer is “flat and at 90 degrees”. You can never tell. -- jack -- measure once, curse twice! |
68 days ago |
Thanks everyone, looks like I have a full day of setting up my jointer. Hope I can find a manual on-line. I didn’t buy the jointer new. I found it in the woods while hunting. But that story has already been told on here. Thanks again, everyone. -- There are three signs of old age. The first is loss of memory. I forgot the other two! |
| Forum | Topics |
Woodworking Skill Share
2913 |
3942 |
256 |
949 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2384 |
LumberJocks.com Site Feedback
524 |
