Cutting box joints on long boxes
Forum topic by JJohnston posted 70 days ago 355 views 1 time favorited 12 replies Add to Favorites Watch
View JJohnston's profile
JJohnston
118 posts in 189 days
70 days ago
I’ve got a project in mind that’s essentially a box 5 to 5.5 feet long and about 10” high and wide. How would one handle side pieces this long in order to cut box joints?
-- Measure twice, then try to figure out which one was right.
View CanadaJeff's profile
CanadaJeff
167 posts in 507 days
70 days ago
With a size that big, my first thought would be forget the power tools and grab a few saws. If you want to go with power tools I would suggest using a dovetail jig with a straight bit.
View LesB's profile
LesB
554 posts in 340 days
70 days ago
Not knowing what tools you have available leaves this question wide open.
There are several commercial dovetail/box joint jigs out there you could use with a router. The best one probably being a Leigh (expensive). They would be the best and easiest.
With care and good supporting jig it could be done on a table saw or with a band saw and chisel. Careful cutting with a jig saw and some chisel clean up would work. With some imagination you could most likely come up with a home made jig to guide your router. Sort of an upside down table saw jig. Finally as CanadaJeff says, use a hand saw and clean up with a chisel.
-- Les B, Oregon
View TopamaxSurvivor's profile (online now)
TopamaxSurvivor
3048 posts in 573 days
70 days ago
I would cut them by hand just like dovetails. If I was in a hurry, I might use power tools to help me along.
TopamaxSurvivor
70 days ago
Suppose I should clarify that. I’d cut the first side with power tools, then mark up the second pice for the fitting if I ws in a hurry. Sort of hard to do it by hand with power tools ;-))
View Kindlingmaker's profile
Kindlingmaker
1475 posts in 424 days
70 days ago
Make a clamp on finger jig and use a router… I would try the table saw but I don’t have 14 foot ceilings, (just kidding on the table saw). ; )
JJohnston
70 days ago
Actually, that’s the main reason I asked, and left it open-ended. Even if I had a tall jig to hold the long pieces vertically, my ceiling height wouldn’t allow it.
View DaveR's profile
DaveR
1527 posts in 618 days
70 days ago
They don’t have to be mounted vertically, do they? Just raise one end on a taller sawhorse that puts the end up at about 48” or so. Clamp on your jig and run your router hand held.
-- Until you spread your wings, you'll have no idea how far you can walk.
JJohnston
70 days ago
Trying to do it on the table saw, I meant.
View Doug S.'s profile
Doug S.
306 posts in 605 days
68 days ago
Trying to do this by TS I think I’d try the following.
Make your llong sides 1 ft longer then machine all 4 sides to width.
Cut 6” off each end of the long sides then cut box joints on the TS using the normal dado/shop made jig setup as if you were making a 6” x Short side box.
Line up the 6” pieces onto the actual long sides and clamp them down.
Hog out the bulk of th waste with a bearing guided router bit, then switch to handsaws/chisels which can be guided by the 6” box joint cuts.
-- Use the fence Luke
JJohnston
68 days ago
Interesting approach. Must resist urge to make “outside the box” joke.
This would probably work pretty well, since at this point a router and a table saw are about all I have.
View RetiredCoastie's profile
RetiredCoastie
229 posts in 80 days
68 days ago
A Japanese fine cut saw, and a good sharp chisel. How thick is your stock?
-- Eagles may soar, but weasels don't get sucked into jet engines! Mike D.
JJohnston
68 days ago
1/2 or 3/4.
